I have a Pioneer iPod adaptor to suit multiple Pioneer iPod ready headunits. This hides away behind the head unit, with a cord to plug in the iPod. This comes with all cables and I have the User Manual on PDF on the computer as well.
Easy to install, has power, ground, plug to iPod and then plug to back of headunit.
This can be used for the following models:
For use with Pioneer “iPod® Adapter Ready” Headunits and AV Receivers. Compatible models include:
* Full Touch-Panel Control models: AVH-P7850DVD, AVH-P6850DVD, AVH-P5750DVD
* Full Rotary Commander Control models: DEH-P9850BT, DEH-P8850MP, DEH-P7850MP, DEH-P6850MP
The following models can control the CD-IB100II through "External Unit Control", with some limitations in operation and display. Please consult the owners manual for more details.
* AVH-P7650DVD, AVH-P7550DVD, AVH-P6650DVD, DVH-P5850MP
* DEH-P5850MP, DEH-P4850MP, DEH-P9650MP, DEH-P8650MP, DEH-P7750MP, DEH-P6750MP, DEH-P4750MP, DEH-P3750MP, FH-P5000MP, FH-P4200MP
Price: $100 ono + postage for those unable to pickup.
Condition: Worked last time I had it with my Pioneer headunit, but the headunit itself jammed up on CD function and so I bought a new headunit that wasn't Pioneer.
Contact: [email protected] or 0401 443 980 begin_of_the_skype_highlighting 0401 443 980 end_of_the_skype_highlighting
Pictures:
More information:
http://www.pioneer.com.au/Products/Car%20E...IB100%20II.aspx
http://www.modyourcar.com.au/pioneer-ipod-...cdib100ii-p4913
https://www.sau.com.au/forums/topic/322174-pioneer-ipod-adaptor/
    • So there is no other way to remove and install the ball joints then to buy the Frenchys kit?
    • Just to close off this post with the cause of my oil consumption issues. Vertical scoring and glazing at the bottom of cylinder 6. I'm not happy, but at least I finally found something. I'll pull it and get it apart asap. Hopefully I don't need to go one size up in piston.
    • I finally got around to purchasing an actual articulating borescope. Great tool to have, I've been very impressed vs my old regular inspection camera.  With that being said, sadly I finally found the cause for my oil consumption. I always had the feeling something wasn't right but compression and leak down tests were always perfect and I had already inspected the cylinders. This time i dropped each cylinder to its absolute lowest point and with the better quality camera I found this... Bottom of cylinder 6.  Scoring looks deep and I'm presuming oil getting by caused the glazing. I already spoke with my assembler, and will be dropping it off as soon as I can pull the motor and get it apart. I'm just hoping it's not deep enough to require boring out from 86.5 ->87mm. Pistons aren't cheap.
    • I think it's the same. It all comes from the same shithole refinieries in SE Asia.
    • I was referring to the final octane level achieved once 10% ratio of ethanol is added.
