Cant say i have had any problems with water in the box/air filter
power duct driven in some fairly horrendous conditions lately in sydney/suburbs, and even in snow/frozen up grill bonnet etc no issues at all
k/n filter in also.
Just a quick update, I asked the Nissan parts counter today for the MAF part number and it is 22680-6N21A(current) and 22680-6N211 is the superseded part number. (VQ25det)
22680-6N201 is the housing tube part number according to their software.
Don't know if its any help but thought I would share anyway.
  • 1 month later...
lol....my AFM seems to have shit itself last night........ :)
Was weird as my wife has had the car for the last two weeks in QLD......she got back last night and I decided to take is for a quick spin :) .......when I hit it the second time it hit the rev limiter and then just died :(
Weird thing is is that the car still runs till 2,000 to 2,500 with the afm plugged in but wont run at all will the plug disconnected.
Not biggy as the car was coming off the road to do some more mod's anyway :D
Edited by Jetwreck
Weird? Nah man, that is just "Limp mode"... it should also be running as rich as hell.
Edited by iamhe77
Thats the Nismo ecu going into "what the f**k sort of driving is that" mode. :)
Did you get the error codes written down?
I hope he didn't kill the nismo ecu!
Would be a worry if it has carked it.
    • And 90% of the time those people turn out to be wrong anyway. But they still treat themselves as a victim...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
