  • Replies 50
scarnon qld...er's!!!!!
the southwelsh pluggers/journos gave themselves the favourites tag..
they said that they should be able to bash the old and injury ridden qld around as per game 3 last yr.
we'll see....
GO THE MAROONS!!
https://www.sau.com.au/forums/topic/322199-queenslander/#findComment-5254868
http://www.dailytelegraph.com.au/sport/nrl...r-1225871315740
QUEENSLANDAAAAAAAH :P
When some one says, "Go The Blues", there's always a tinge of doubt but...
When a Queenslander yells, "Queenslandaaaah", there is no doubt!
lol
https://www.sau.com.au/forums/topic/322199-queenslander/#findComment-5254944
Go Banana!!!!
I mean, go blues!!!!!!!!!!!!!!!!!!!!!!!!!!
yes will be quite cold out there tonight, good job Im going to snuggle with s13deviat LOL
:D:O:P
reacharounds potential
Only if he butters me up with beer beforehand!!!!!!! :P
https://www.sau.com.au/forums/topic/322199-queenslander/#findComment-5254987
