  • 10 months later...
  • Replies 50
Actually if it wasn't for a lot of bullshit calls from the ref, this nsw team is showing signs of being able to work out well maybe not this year but next will be a good team
+1
not to take the win away from qld (they played well for the first 20 and the last ten..), The ref did make some shit calls...foward pass of that kickoff...my arse.
However, Nsw is showing some promise for the first time in years; should make game 2 interesting
  • 3 weeks later...
Waddagame!
So much for no size = no win.
Gallen and Beau Scott hammered the QLD big boys into submission.
And Pearce jnr made "third man in Thaiday" look like an amateur.
Absolutely loved the look on his face when he realised he'd just been smashed for the 10th time by a little number 7 :)
    • 95 is just a scam outright. 98 is the real "premium" with all the best detergents and other additive packages, and at least historically, used to be more dense also. 95 is just 91 bargain basement shit with a little extra octane rating. Of course, there's 91 and there's 91 also. I always (back in the 90s early 2000s) refused to put fuel in from supermarket related fuel chains on the basis that it was nasty half arsed shit imported from Indonesia. Nowadays, I suspect that there is little difference between the nasty half-arsed shit brought in by the "bargain" chains and the nasty half-arsed shit brought in by the big brands, given that most of it is coming from the same SEAsian refineries. Anyway - if there's still anything to that logic, then it would apply to 95 also. 98 is only made in decent refineries and, as I said, is usually the "premium" fuel, both in terms of octane rating and "use this because it's good for your engine because it's got the unicorn jizz in it!".
    • Yeah since those first 2 replies I actually went and put some 98 in it and tbf it's already doing much better than the 95 (which is weird and makes my inner tinfoil hat wearer think the 95 was a crap batch), getting 8ish around town. Again, wonder if it takes a while to stabilize if the fuel is changed a couple of times. I swear cars used to just either run "well" or "s**t* in my 20s, none of this fuel optimisation business haha
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
