Hi LAD`S & LASS`ES,
OK RIDE HEIGHT`S WHAT you HAVE,
PLEASE PHOTO`S OF FRONT & REAR`S,
Type of SHOCK`S & spring`s PLEASE,
I will start with FRONT`S just need to fit rear`s to day & will POST ,
Ohlines with rsr spring`s,Stock & Ohlines now Ohlines is 35mm shorter then stock ok,
Cheer`s Chuckie.
https://www.sau.com.au/forums/topic/322241-ride-heights/
Is your car green, Bob? If so, it's more of a twin to my car than Hugh (66yearold)'s or his son's - neither are s1 RS-Four's converted to manual!
Mine's lowered on the Sydneykid Bilstein/Whiteline set-up, no idea of front and rear ride heights, I'll have to measure them later.
Old photo:
https://www.sau.com.au/forums/topic/322241-ride-heights/#findComment-5255688
Ok ,
Back`s in & ride height is 380mm :) ,
Rear Shock`s are NISMO,
so here`s rear height & pic of Shockie,
Side on of car too ,
post-36964-1274856319_thumb.jpgpost-36964-1274855998_thumb.jpgpost-36964-1274855154_thumb.jpg
Cheer`s Chuckie,
PS,SIDE ON PHOTO`S Would be BEST as we all see what car look`s like , :P:(
https://www.sau.com.au/forums/topic/322241-ride-heights/#findComment-5255865
Yep my car's dark green like yours (not so keen on the light green) got an R33GTR box and looking for some R33 or R34 GTR rims!
Old photo:
https://www.sau.com.au/forums/topic/322241-ride-heights/#findComment-5256926
Looking good there SABBAi mine is opposite to yours 340 rear and 330 front, I am thinking of changing it to 340 all round, bit worried about to much camber and killing my tires.
I hadn't even given the cv joint a thought
https://www.sau.com.au/forums/topic/322241-ride-heights/#findComment-5258629
Not sure what my car is at, but it's low and i had it up on the hoist today. The inside of my tyres are f**ked due to the camber! as are my front CV boots, Just more money i can spend on the car without adding to it's appeal. yay haha
https://www.sau.com.au/forums/topic/322241-ride-heights/#findComment-5258997
i'll point it out again in this thread, tyre wear is due to bad toe settings (excessive in or out)
you can have tyres last a long time with alot of camber
So i ha a quick look, what do i need to get to adjust toe setting?
https://www.sau.com.au/forums/topic/322241-ride-heights/#findComment-5259414
I agree about the incorrect toe killing tires really quick because thats how i killed my first set they only lasted a year and totally bald.
if you have the right camber setting's your tires will last a lot longer then if your running a lot of camber from lowering your car, in time the inner corner of your tires will be worn and the outer will still have plenty of tread left, if you where running correct camber all of your tires would wear evenly,
well that how i understand it, correct me if i am wrong
https://www.sau.com.au/forums/topic/322241-ride-heights/#findComment-5260415
I know it will shag out the inner edge of tyres quicker than a sensible camber setting.
I am assuming the significant negative camber is being used for cosmetic reasons but I can't understand why a proper alignment wasn't done and all variables were checked and adjusted when new rims or suspension height changes were made.
To me it seems obvious that if you don't check and set all aspects you will get excessive tyre wear.
https://www.sau.com.au/forums/topic/322241-ride-heights/#findComment-5260565
my comment wasn't directed at you wolverine, i was questioning mike's comments about the correct toe, I am no suspension expert but that was how i understood it
https://www.sau.com.au/forums/topic/322241-ride-heights/#findComment-5260594
???????????????????????????????????????????? assuming you rotate the tyres often and have totally neutral toe, what's your solution with negative camber (say, 3 degrees negative all round), to wear out the middle of the tyre?
https://www.sau.com.au/forums/topic/322241-ride-heights/#findComment-5260669
of course if you run a lot of camber you'll get uneven tyre wear. that's pretty self explanatory.
my statement is that you can get plenty of life out of your cambered wheels if you have good toe settings. it is to do with camber thrust, which i won't go into detail, but this may explain it to most
When a wheel is set up to have some camber angle, the interaction between the tire and road surface causes the wheel to tend to want to roll in a curve, as if it were part of a conical surface (camber thrust). This tendency to turn increases the rolling resistance as well as increasing tire wear. A small degree of toe (toe-out for negative camber, toe-in for positive camber) will cancel this turning tendency, reducing wear and rolling resistance.
https://www.sau.com.au/forums/topic/322241-ride-heights/#findComment-5260670
you're missing my point i think, and i'm a little confused as to what you're trying to ask?
if you're running 3 degrees negative camber of course you're going to suffer from tyre wear to the inner edges, and if you rotate them you'll end up with worn shoulders on both sides with more tread in the middle - which is the norm.
if you want your tyres to wear dead even, then run zero static camber (which i wouldn't recommend) but even still they won't wear dead even due to independent suspension and dynamic camber (camber changes under load).
my original point is, if you want to get the most out of your tyres with a little negative camber, run a couple of degrees toe out
i hope that's helped?
https://www.sau.com.au/forums/topic/322241-ride-heights/#findComment-5260679
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
