my gtst at the begining of april 09 since then ive been doing stff to it
When i got it it had splitfire coil packs a uprated gasket exhaust and down pipe and a profec b 2
this is how it was
so ive fitted a ally rad fmc and oilcooler with push fit pipes and a intercoolerand clipped and replaced most of the hoses in the engine bay
the intercooler mad the usual flat spot so i purchased a pfc and datalogit remapped it andsorted out .The oil cooler made a massive difference as the oil temp would be 105 degrees when being pushed no its max is 90 degrees so thums up to that
ive fitted a carbon splitter i made to the spec2 bumper as i dont like the aftermarket bumpers
the 18inch repo bbs rims
got a spare engine which had lost compression so i stripped it to see what it was
3 pistons were shot but the bores were ok so sent everything off to get machined with new pistons and rods acl bearings ect and just got it all back
block
painted up
https://www.sau.com.au/forums/topic/322253-my-skyline-from-the-uk/
head with valves all in
lifters in
cams in
also a the car is also my daily so we have been putting the cage in as and when we have time so here it is
nest will be the door bars and tags and seat bars but just waiting for these to turn up
.::Welcome to CORBEAU.com
then ill make my carbon bonnet and really cant make my mind up wether to make some doors or just buy them
Some latest pics
i made these
what do you think
lifters in
cams in
Some latest pics
i made these
what do you think
beautiful
obviously looking to do some track work. what other plans for it, engine suspension brakes etc.
love the door trims..
ive just purchased a link g4 and a gt3071r my spare engine i have tomi pon b cams, suspension at the moment its cusco coil overs but for track there very under damped so i use a company called gaz do they are building me at set of coilovers that be weighted to the car and sprung correctly ! the car is built to fia standards which is basicly the British clubman race regulations but at the moment its just track use . I do all my own carbon work i have just made a bonnet to no pics as yet tho but i can do carbon infusion and wet lay so i have some fun with that
i feel a bit of a coward though as ive dropped the compression to 8.5.1 i here you boys run high with big horse power . Australia are alot more forward than us in tuning thats one of the reasons i went for the link and ditched the power fc plus i like mapping pressure verse rpm rather than maf verse rpm
Hi Jason, great work,
Car`s come on well,
I grow up suffolk/ norfolk , lowestoft ,& the Market weston just out of Diss 16 mile`s from Sennertton,lucky you have few TRACK`s around you to give the SKLINE a workout,
Roy Have Famliy in Cambridge,use to go out on MONDAY night`s with Few Race Driver`s lol,oldday`s mid 80`s
Jason look`s like few SKYLINES getting in to UK now,
Best of luck with your TRACK DAY`S & hope you give then something to think about ,
cheer`s Chuckie.
cheers Charlie ! there are loads of skylines in the uk now ! we use snetterton for testing and race there 5 to 6 times a year
Hi Jason,
Sweet suit SKYLINE with long back straight :D ,
& you musy love BOMB HOLE :P:P ,Loved it there great TEST TRACK LOTUS used to TEST MANY MANY YEAR`S Ago,
+ VAN D`s we would pop over road & spend day ENGINE testing,
I do miss going there, as WE have a GOCART track here as are MAIN Track :D ,
But I LOVED to head up to CADWELL just an wonderful mix & GREAT FUN OVER MOUNTAIN :D:D ,
But there`s Lot`s of top spot`s just depend`s what your LOOKING for,
So BEST OF LUCK WITH SKYLINE ENJOY ,
Cheer`s Chuckie.
Hi Jason,
& you musy love BOMB HOLE :D:P ,Loved it there great TEST TRACK LOTUS used to TEST MANY MANY YEAR`S Ago,
But I LOVED to head up to CADWELL just an wonderful mix & GREAT FUN OVER MOUNTAIN :):) ,
Cheer`s Chuckie.
my favourite track is brands hatch indy circuit bloody good drive lol you sound like you miss the uk charlie
Hi Jason ONLY thing i MISS IS MOTOR SPORT THERE BOTH BIKE`S & CAR`S ,
Was BIKE MAN BEFORE & YES MISS THAT,
BUT DON`T MISS SHIT WEATHER :yes: ,
Having work with both ,
Edited by chuckie
    • I agree re not trusting it as it makes mistakes however can do hours of research for you at times by simply asking a question
    • The I've done a lot of research and feel like I'm becoming a nut and washer expert. The washer in question doesn’t look very conical—it’s almost flat, but one side has a chamfer. The guide's picture shows the convex side (chamfered side) facing the nut, but the text says the chamfer should face the pulley, which is confusing. If I follow the picture, the chamfer faces the nut, but the instructions say the opposite. When I place the washer on a flat surface, one side looks flatter—maybe that's the concave side—so I would expect the chamfer to be on that side. But it isn’t, which adds to the confusion. The term chamfer is also throwing me off. I always thought the concave side should face the pulley, and the convex side (with the chamfer) should face the nut or bolt head. But Nissan’s instructions say the chamfer should face the pulley, which seems backward. I know I’m probably overthinking it, but I want to be sure I’m doing it right. Also, I’ve seen some people replace the nut and stud with a bolt, but I assume that’s not a good idea, since it might not keep proper tension on the tensioner. Lastly, just to be 100% sure: the pressure washer should face the pulley, then the conical washer? That feels strange, since usually the pressure washer goes first, facing the bolt or nut.
    • I checked, i dont think it was the indicator stalk. The problem just magically fixed itself though.
    • H1 is not the Humvee, but is the most road based version. Lachlan (HankScorpio) on here has a proper Humvee. He imported it a few years back.
    • Welcome Thomas! Sounds like you've made some progress. Are you able to drive it and enjoy it a bit now ?
