I have a heap of R33 GTSt parts for sale.
All the standard interior as well as the bonnet, rear brakes, rear spoiler and gearbox.
Most of the interior is in good condition, just the standard wear you get from 17year old stuff.
Bonnet is maroon and needs to be painted otherwise straight and rust free.
Make an offer on what you want
All the stuff is located in canberra, i cant be contacted on 0408 915 156 or [email protected]
Regards,
Cristian
Edited by Cristian
https://www.sau.com.au/forums/topic/322288-r33-gearbox-and-other-various-parts/
Regards,
Cristian
Hi,
Condition of gear box and price please
0433878905
Alex mordialloc 3195
Hi,
0433878905
The gearbox is pretty good condition, it has a 165000kms on it from a s1 r33
always shifted nice and no noisey bearings, has been well looked after while ive owned it. It has been out of the car for over 12 months now.
im asking $1200ono
Cristian
I have some more stuff to add to my garage sale of skyline parts
RB25 engine, needs head gasget minus coils and Crank angle sensor. $1200
RB25 head, with cams only $800
RB30 block only $250
Complete RB30 engine $600
R32 GTR body, missing a heap of parts. ok for spares only, diff, driveshafts. windscreen, rear quater panels, hubs, coilovers, etc $1800
R32 RB26 with spun bigend, no exhaust manifolds or turbos or coils $1500
HICAS ECU and rack from R33 GTST $250
Plus everything still listed in my first post
Cristian
Edited by Cristian
  • 2 months later...
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
