Apexi Power Fc
bij44p
 Share
hey fellas im new to this site hoping someine expertise can help me about 8 months ago i invested in the well known apexi power fc not knowing that you CANT just remove the stock maf sensor so im in need of advice in which way to go try get a new computer and sell mine or does someone kno something you can do that i dont cause im in the process of modifying i have already done greddy plenum coil packs 3 inchzorst all way through regular stuff but the stock turbo im pushing 17 psi out of it wen its on the road i think its time for an upgrade but this maf is a problem or can anyone give me feedback on a blow by system and response would be super thanks guys :P:(
ouch. my brain hurts lol.
Firstly, welcome.
Secondly, the "Forced induction performance" section will help you out a lot as well, probably get a faster reply.
Thirdly, if there's nothing wrong with your PFC and you sort out a new ECU, I'm interested in buying lol
and finally, 17psi out of stock R33 turbo??!!?!?!? f**k me maf sensor won't be your problem soon lol
Firstly, welcome.
exactly. the stock turbo becomes a time bomb above 13psi, so if i was you i'd be expecting it to blow any time now. it may last 6 months, it may last a year or it may blow tomoro, but it will blow (unless of course it has been highflowed, then it will be fine).
also at 17psi on the stock turbo you are probably getting out of it's effeciency range. you'd be able to drop it down to 15psi and be making a similar amount of power but be somewhat safer on the turbo (still not ideal though).
as for the ecu, one option is to go a z32 afm. they are the same size as the rb25 one but read in a slightly different resolution, so you will be able to get up around 250 or 260kw from it before it starts to max out.
oh and welcome
hey thanks for the reply guys :D
i am currently lookin into the z32 maf but wat does it need to hook up the the stock maf loom ?
and the turbo thing... its got a dual stage runs 6psi low boost and 17 psi high boost it made 189.7 at the treads with stock exhaust yumcha fmic dual stage boost cont and apexi power fc is gunna be retuned in two months with new fmic full 3 inch zorst new coil packs (custom plenum greddy ) hi mount turbo but dunno wat turbo yet any sugestions for size ?
and thanks for the ideas and replys guys :)
 Share
    • Unless there's something particular about the Greddy manifold's injector holes that I'm not aware of, those injetcors look to be totally wrong. They would absolutely want to be spaced up to get those long snouts out of the runner. Which, I think, is not usually the way that that problem is solved. I think the problem is solved by using the correct injectors, which would be much more like what Andrew posted.
    • Thanks for the reply, So i've continued playing around, and fitted the injector adaptors onto the injector, the fuel rail is not able to be mounted now as the injectors sit a bit further out. I suppose the point of the adaptors is so that the injector nozzle isn't so deep into the intake? I suppose 1mm extra on the o-ring would do it but still can't mount the rail onto the intake haha. Waiting on a reply from Aeroflow I'm sure there's something stupid that I'm missing...
    • EMJ33 or EJM33 - west end
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
