my new walbro gss342 arrived today for the stag...
was going to wack it in. is it really worth doing this mod that you wire it up to get a constant voltage.. or should u just put new fuel lines onto the pump and fresh wires leading up to the top of the tank??
http://www.skylinesaustralia.com/forums/wi...mp-t234796.html i
i was going to follow this...
i was told by Sean at boostworx that its not really needed, i've got a GTR and he told me the wiring on it is fine and there is no real point. its other cars like silvia's and 180's that might benefit from rewiring it.
I use a Walbro in my 180SX.With pump set up with standard wiring it had bugger all fuel pressure as it would only get around 9volt max.
I then wired it with bigger gauge wire for power via battery and standard fuel pump relay and new earth, it then gave perfect fuel pressure running the pump at near on 14 volt.
Walbro pumps need to be getting near on 14volt to work at their best. And as always keep the earth wire as short as possible.
Edited by slippylotion
thats some good info to know.....not sure if the bosch and the walbro are the same but mine has worked fine for the last 2 years
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
