Ok so Im currently in the process of getting the head sorted for the L24 in my c110,
Unfortunately the original head was well and truly stuffed.
SO i got a E88 head of an 260z, but the guy i was going to use to get the head ported crack tested etc, is adamant that it will not work without Dropping the compression way way down.
I always thought for the most part the heads were more or less interchangeable, another mate who has done it all b4 tells me that it will work with out a problem. I guess i want to know who's correct. and who the fuc can i take the head too that will be happy to do the work!
thanks in advance!
https://www.sau.com.au/forums/topic/322396-head-help/
What are your plans for this head??
You doing a turbo conversion or normally aspirated (carby) engine???
If your going with your stock OEM carby set up, you might want to look at multiple carbs (twins off 260Z) or maybe a Webber for better response and a better cam, but for the most part it is interchangeable and your head guy has his head up his proverbial ass.
You might get a slight increase in compression with the E88, but that, I think is a good thing, as most of the 240K's were a little lacking in the compression dept and your not going to see any pinking until you're approaching the 10+:1 mark and or trying to use standard ULP fuel.
Remember your 240K was about when super grade fuel was about 95+ RON octane and it had lead in it to boot.
Cheers, D
https://www.sau.com.au/forums/topic/322396-head-help/#findComment-5258242
The only super fuel, mass produced in my day that was 100+ RON octane was Fleetwing 100. It was produced by the Boral Refinery at Kurnell and took the NSW performance car industry by storm and was soon bought out by Caltex and shut down.
If you do your research & not have a shot in the dark, I think you will find about 97 RON octane was the standard off the shelf Super grade leaded petrol produced until it's demise.
D
https://www.sau.com.au/forums/topic/322396-head-help/#findComment-5258554
Thanks Guys, im all for more compression, this is for my stock AUTO coupe so im not overly worried about cams and webers ...... atm,
my other c110 used to love E10 Unleaded 95ron did the trick for a fair few years.
https://www.sau.com.au/forums/topic/322396-head-help/#findComment-5258622
It would be a very good idea to change the cam when you're changing the head. That's why I suggested the cam change.
Out of interest, what cam is in the E88 head you acquired?
Cheers, D
just a stock 260z Cam, i know its going to be better than what my other coupe in it, i will be sure to check out the option of a new cam tho.
https://www.sau.com.au/forums/topic/322396-head-help/#findComment-5258829
Slide the cam out of the towers & check the code stamped in the back.
If it's a C you have the best cam you can get for your car, be better if it was a manual, but such is life.
If you want to upgrade your carby to twins, try to source a manifold & then source the twin SU's off the Triumph 2500TC. The 2500TC SU's are 1 3/4 as opposed to the 1 1/2 on the 240 & 260Z's. They might be a bit sluggish off the line, but mid to top end will be exemplary.
Cheers, D
https://www.sau.com.au/forums/topic/322396-head-help/#findComment-5258880
Cheers, D
Well its an 'A' Cam.
https://www.sau.com.au/forums/topic/322396-head-help/#findComment-5260202
Im not going to argue with the fugures, but a sprint car racer told me this. not a stab in the dark.
https://www.sau.com.au/forums/topic/322396-head-help/#findComment-5265242
I run a 'A' Cam on my turbo L24, from my research, it the best 'N/A' cam to use on a turbo engine..
Nigel
That's interesting Nigel, Stewart Wilkins thinks the same way and I have an A cam here for future testing, but for now, I'm building an L28et with some fairly wild cam timing, trying to produce sh!t loads of Torque as opposed to mass HP. I'm going to use a cam in the 256 degree bracket plus a vernier cam gear.
D
https://www.sau.com.au/forums/topic/322396-head-help/#findComment-5266076
D
I foud out about it, from here,
http://forums.hybridz.org/
one of the members, who builds heads and such mentioned it, and he know what he's talking about.
Nigel
https://www.sau.com.au/forums/topic/322396-head-help/#findComment-5266275
Sorry to wade into this late, but I'd just like to recommend you use your stock E88 head with your stock L24. The E88 head has large round combustion chambers (rather than small kidney-shaped ones) so you should actually get lower compression than some of the other L heads around. BUT! You do get the largest intake valves, and almost the largest exhaust valves of all the L heads, so it's going to breathe very well.
In addition, your L24 has slightly dished pistons (if it's from your 240k), so overly high compression is not going to be an issue. In fact you could consider a 1mm gasket to increase the compression some given you'll have a little extra valve clearance to play with. I've run an E88 with flat top pistons with no hassles (other than my own incompetence putting it together).
Finally, give Motor Improvements a call on 9555 8278. Last they were in Bricker St Cheltenham, but they were looking to relocate, so I'm not sure what their address is now. They help me out quickly and cheaply every time I smash up my heads (which is alarmingly still quite often). They won't lead you down the garden path.
https://www.sau.com.au/forums/topic/322396-head-help/#findComment-5266384
Thanks Man ill get in touch with them tomorrow
https://www.sau.com.au/forums/topic/322396-head-help/#findComment-5266676
On the topic of heads, did any L series 6cyl heads come in crossflow?
Only one!
OS Giken made it for the race 280ZXT's & they were DOHC as well and I haven't seen one since the very late 80's.
And parts for them are no longer available.
D
https://www.sau.com.au/forums/topic/322396-head-help/#findComment-5266995
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
