  • Replies 43
VSPEC: written in the newsletter is NOS=YES, SLICKS=NO as the only restrictions.  where'd you make that up?
I didn't make it up, I spoke to the guys running the dyno, there the ones setting the rules not the newsletter:p
And how exactly were they measuring boost in the V8's, I didn't see them hook up a boost line, did you?
Jap cars rock, V8's suck:p
i had the same thoughts as to how they were going to measure boost, and was confused as to the conflicting info. the info on nos was supplied to me in the entrant info pack, and then a different thing was displayed upon registering the cars.
not my mistake, ask the dyno guys why it kept changing
love the objective approach tho keep it up.
indeed you are. I see little of the bs that comes in this industry from you Steve and its commendable. Did i mention i need to recover my head from you cos after that some will claim its stuck up your butt :P
As for Ant, he is Ant - need I say more ?
Simon farts alot but he is cool too so its all good down there. Just get rid of that girl who talks way too much .........
i didnt enter a v8 so no excuses guys, just a bit surprised at the rather poor attitude taken towards other performance cars. dont want to start a shit fight but there were cars making twice that power years ago at the summernationals. not to take anything away from the gtr's awesome performance tho, or any of the other cars there
    • Found it thanks, the front tie rod end should be torqued to 40nmish
    • Ok I thought my allow had a flat back but it does have grooves for the spacer nut/ no cutting needed   bolt and nut sticking out from the spacer around 12mm and the groove is around 24mm so all good   appreciate the help chaps
    • Back in 2016 bought a set of front and rear bracket set and changed all 4 corner discs and caliper   i was checking the car and seen rust like or in another word crumbled part of the bracket which came off with a air blow   is this normal? This had happened in two areas and car from 2016 has mostly been in garage/ doing less than 2000 miles over past 8 years or so pic with areas highlighted in red   https://ibb.co/NtmWXZt   also anyone knows the torque spec for the bracket as want to retorque them, one bolt had come off half way !
    • So if I was to spend 400r money and remember I am only here because I need 4 doors because of an incoming kid otherwise I would be looking at a lexus RCF what am I loosing out on other than fuel economy but gaining in power and space / V8 sound on Chrysler 300c STR Vs nissan 400r?, I will admit that buying the VE bomadore was an eye opener into build quality compared to Jap cars... https://www.carsales.com.au/cars/details/2020-chrysler-300-srt-core-auto-my20/SSE-AD-18201088/ but this one is on the same money...
    • If you're friendly with a workshop that has a large scraps bin you can always ask to dispose of there. Otherwise theres always the places like sims metal etc depending where you are at https://recyclingnearyou.com.au/cars
