ok so was stuck it traffic tonight and getting annoyed... finally got some open road and give it a bootfull in 1st gear...
all of sudden I hear a small bang and see black smoke in the rear view mirror...
then there is no boost... the car spools from negative to zero... and nothing from there...
it drives fine if u dont hit boost... idles fine... no smoke or anything...
and im pretty sure the exhaust note has changed... almost like there is something stuck in the cat (or it could just be my imagination)....
so one of the turbos has let go yeh?
i'm almost certain its the turbos from reading what others have experienced...
checked for leaks in cooler piping... seems all fine...
car is pretty much standard... running cat back exhaust... and 15psi actuators (came with the car! should have taken them off :@)
https://www.sau.com.au/forums/topic/322435-no-boost-r33-gtr/
Yep, bye bye ceramic turbine wheel!
Hopefully the bores are not damaged from ceramic dust. I've seen first hand what can happen to the bores.
I've got some new 2860-9's to replace the stockers on mine. Not gonna take any chances!
Good luck!
so what do you guys think of the following idea:
I grab some 2860 - 5s and whack em in... was planning to get those all along... might as well upgrade now
now the car is completely standard... doesnt even have a full turbo back exhaust yet... so I'm not sure how the Garretts will work on the standard car...
will probably have to run like 5psi until I get all the supporting mods (PFC, exhaust, injectors, tune etc etc)...
any thoughts on how much boost should be run in this sort of situation...
what he means by the dust is the tiny particles from ur ceramic exhaust wheel(s) when it pretty much explodes.. get reverted back into the engine if u come off throttle and do damage, if the car is fine atm, dont be worried..... just yet ;)
sounds like the exact same thing that happened to me,
put foot down
boosted up
BANG!!
black smoke out the rear (lots of it!!)
drove like a n/a car not building any boost.
replace the turbos and hope that there was no damage to engine, i was unlucky enough to replace the turbos after they blew then the front conrod bearing went so i had to get a full rebuild a week after the new turbos were installed.
good luck mate,
i went the 2860-5's, they're a bit laggy, but now with the boost up to 19psi it really does pull hard all the way to 320rwkw.
Drop the front of the cat and see if its looks like this; that's bits of ceramic turbine.
What's your power goal? -7s or -9s are probably a better choice than -5s unless you're going to rebuild the motor and go for something like 400kws...
Too bad theres no smoke. Mine sort of have the same thing happened only that the bang was THAT loud and was blowing black smoke. Found out that the intercooler pipe (dont know if its the term for it but thats the black bit connected to the "twin turbo" pipe) was loose and came off. Tighten it and no issues after that.
how about you check all of your intercooler hoses first mate, particularly the bottom driver side one and the top passenger side one (inside the front wheel arch)
if your car is stock standard I doubt it is a turbo
Check these first intercooler piping if all good, take the cat out. Do you still have oil pressure? (if so, re-check the hoses).
It happened to me a month ago (was expensive trip home by tow truck!) the culprit was the clamp that hold hose was broken, passenger side near the chassis rail - common problem.
My goal is 320awkw...
from reading the RB26 dyno thread... it seems like some ppl were falling short of that power with the -7s... will do some further research before buying tho
I will have another look at the piping tomorrow... had a look last night... was dark so may have missed something...
but from what I have read it seems like if a pipe has come loose... you still get some smoke when driving afterwards...
I'd rather preprare myself for the worse and either be relieved when I hear it was just a pipe or not be surprised when I eventually do get confirmation that it was the turbo...
just hope these bores are still ok... car seems to drive fine (just without boost) if thats any indication...
BLARDI 15psi ACTUATORS!! was planning on taking them off this weekend too :(
I'd be going with -5's for 320-330 on stock internals... You'll make the power easier- thus keeping your internals together longer.
OR Have a look at Trust T517Z 8cm's... I prefer them to Garetts.... Especially now that Garett/Honeywell have started cheaping out on they're production quality and standards...
Port match the stock exh manifolds and fitt quality dump pipes while your at it.
J.
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
