Doing the usual head splitting search on the net for intercooler options for my S2 stagea and I am wondering if the same side inlet/outlet coolers are an advantage over the turn flow style. Just jap has a cooling pro version and on Ebay.com (usa) there is also a couple of other similar products with diferent style end tanks. The 2 advantages i can think of are 1. less piping and a little better response 2. no pipe hanging under the intercooler. I am only running stock turbo with a ebc 10 psi at the manifold 3" exhaust k&n panel and will get it nistuned. I have read that the stock smic is bad for heat soak and as i live in WA where it can hit 45 in summer i dont want to risk it.
https://www.sau.com.au/forums/topic/322455-same-side-inletoutlet-intercooler/
Unless and until you get a bigger turbo I wouldn't bother. I was making 220kw with a smic on my S1 Stagea - upgraded to a S2 like yours and then to a Nismo. The only time there was any "heat soak" was during an extended dyno sesion when the fan was directed at my radiator and virtually no air through the side vent to my smic.
Wait and see if it becomes a problem. By that time you might have decided that you want 260kw and then you'll have to get a bigger front mount than a small return flow type.
Cheers for the advise, but it now leads to this qusetion. What are the indicators of the intercooler not performing ie heat soak issues, under normal driving conditions, would i expect to see an increase on the temp guage? Loss in power or KA BOOM!! I really dont plan on going for any more than the stock turbo, I got the 260+kw bug out of my system years back and just want this as a nice cruiser/family car utalising all nissan put into their factory engines.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
