Hi all
I have a GTI-R that I have converted to RWD by welding up the centre diff and pulling out the front diff and shafts.
When i have managed to over cook it sticking the back end out then started spinning out, iv'e jump on the brakes, the brake pedal has gone solid and i seem to have little to no brakes at all. This has happen 4 times now and i'm a bit over it.
The car has ABS and it doesn't seem to matter if the clutch is in/ out. It seems to be more than just losing vacuum to the master cilinder but i could be wrong. Brakes and hand brake work well at all other times..
Any ideas why this is happening? if its linked to the ABS system?
Cheers.
ive had a similar problem with my old GTiR. i found that i was missing a nut on a control arm that came directly off the thottle body's. hard to explain. so heres a pic i edited of my old pulsar. hope it helps. got the problem spot circled in blue... if you look real close at it you can actually see a shiny new bolt there!
Pull the ABS fuse and retest... ABS doesn't like when you go forwards then sideways then backwards.. I have tried to hit the brakes after doing a burnout in many abs cars. Abs goes mental, pedal goes hard, car takes ages to stop.
Hooked the relay and switch up tonight so will see soon enough if it has worked.
Gtir doesnt look anything flash, attached a pic. Found an oldy but a goodie of my old evo stuck in the sand dunes too. Fun times.
Will get around to making a GTIR video at some point soon hopefully. Need a bit of practice first so i dont look like a rookie.
