Item Summary: Tomei HICAS Lock II
Condition: New / Opened Box
Reason for Selling: Not needed
Asking Price: $150
Delivery Methods: PickUp
Contact Info: PM or post
Extra Information: I received a Tomei Lock II kit, along with some other goodies the previous owner hadn't fitted yet, after purchasing an S13.
I'd prefer to do the mechanical HICAS lock to shed a bit of weight so looking to sell this kit.
The box has been opened so I'm not sure if it's complete (it looks like it is though) but it is new. It's also a genuine item.
For those who don't know, this is a convenient way of locking HICAS without all the mechanical nonsense involved. It's also easily reversible should you want a better turning circle :)
This will suit pretty much any vehicle with HICAS
There are no english instructions though although they are available online. Basically it interrupts the signal received by the HICAS computer to tell it everything's OK and there are two shims which lock the rack underneath.
Can meet in Brisbane or post at buyers expense.
Sorry for the poor pic.
https://www.sau.com.au/forums/topic/322470-tomei-hicas-lock-kit/
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
