1992 R32 GTST
excellent Silver paint
HKS Hyper turbo back exhaust with high flow cat
Pioneer CD player
aftermarket front and rear speakers (Pioneer rears, and JL front)
Pioneer amp
rego 11/04
GTR rear wing
rear pods
Autometer (silver-faced) boost gauge
serviced every 5000kms
Upgraded Bosch fuel pump.
Repadded front drivers seat.
Garaged
115,000kms
Pics are available at:
http://groups.msn.com/paul17maher/shoebox.msnw?Page=1
Price: $15000
Contact: 0412591369
Willing to consider a trade........
https://www.sau.com.au/forums/topic/32251-wanted-r32-gtst/#findComment-659563
'92 R32 GTS4
101,000kms
Bar & plate Hybrid FMIC
17 inch Work equip wheels
Brand new Kuhmo ectsa supra tyres
R34 turbo @ 10psi
R33 GTR Fuel pump
3 inch exhaust from dump pipe
GTR V spec II shocks
Lowered King Springs
HKS EBC
HKS sequential BOV
HKS turbo timer
Autometer boost guage
Polished engine
Nismo gear knob
Airfilter
Front strut bar
Tinted windows
Factory 10 Stacker CD player
Parts not fitted.
Adjustable fuel pressure reg.
SAFC1
Custom chip for ECU
Oil catch can
Stock wheels with almost new falken ziex tyres (90%+ tread),
Timing belt and water pump changed at 80,000kms.
Serviced at 5,000kms intervals if not more frequently.
$18,000 neg
https://www.sau.com.au/forums/topic/32251-wanted-r32-gtst/#findComment-659712
hey guys here are the details of my car
TOYOTA COROLLA SX 1991
Supercharged 4agze conversion with gearbox, engine mounts and all, and swapped the hubs over
(its all out of the AE101 Levin Coupe halfcut I got)
Re-worked computer 10psi,
Heavy duty TRD clutch,
HKS air filter,
2 inch exhaust system with a cannon sports muffler,
Front and rear disc brakes with new pads,
New cv joints,
Monster tacho with red shift light and boost gauge,
MOMO Sports steering wheel 13inch,
MOMO gear knob
Tinted windows,
$3000 stereo system
(pioneer 9450 headunit, sony explode 6” x 9” , pioneer 5½” splits, 12inch Rockford fosgate sub and Rockford fosgate amp, in sub box which is bolts to floor)
Lowered 2.5inchs,
15" hyperfang rims & matching spare & spare standard corolla rim,
Power steering.
Aircon (not gassed)
Good condition inside and out,
It has rego till next September so about 9 months,
The engine standard was 123kws, and now it’s at 145kws at the flywheel
It only runs on premium fuel. (I’ve only ever put in shell optimax)
I got the car in August 2003.
The conversion was only done 6 months ago,
The engine was purchased with only 82,000kms, got all receipts.
and I’ve done about 13,000km,
Serviced every 5000kms
Had a Major service done on 20/1/04[/size]
https://www.sau.com.au/forums/topic/32251-wanted-r32-gtst/#findComment-659806
I have a black r32 for sale if ur interested Dec 1992, manual, 5 puck button clutch, 3"zorst, HKS EVC, Apexi Multichecker, strutt bar, k&n filter, bov, AM fuel pump, AM fuel regulator...but 2 air vents on the dash need to be replaced cus my girlfriend broke them. also comes with a t4/t3 hybrid turbo that needs a rebuild that you can chuck in at a later date, i was told it supports about 500hp. if ur interested email me for pics i have a few of them. [email protected]
https://www.sau.com.au/forums/topic/32251-wanted-r32-gtst/#findComment-665591
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
