Control arms on.
Turbos, intercooler piping and intake all arriving tomorrow so engine going back in tomorrow arvo.
MCA suspension and whiteline antiroll bars go on Saturday
Tuning Sunday
Rest on Monday (Holiday up here)
Track on Tuesday!
Just awesome! I can't wait to see it on the track!
will be good to catch up Stuart.
the car will be without the AMS intercoolers most likely as I doubt they will have arrived. We will be running a pretty conservative tune. Should be fun!
Dunc,
car still up on the hoist. engine going back in today and suspension on saturday so will know more beginning of next week.
These control arms were used by an aussie GTR that visited the Nurburgring i think? though I have only received this info second hand. I am not sure which car they were on though. Maybe someone out there in the SAU motorsport community knows more??
will give a report next week when we have the info for you.
Dunc,
i look forward to your report Mark, thanks.
Wow, what a massive day!! Lots of time spent tidying up all of the finishing touches and fitting all the parts that we had purchased for the car. Here are some of what we got done.
Heat wrapped the dump pipes - i think it was a shame to cover them, they looked hot!!
work experience kid unwrapping the whiteline swaybars and link kits
Whiteline goodness!
Whiteline Rear swaybar link fitted
Whiteline Link and bar fitted (set on soft for now)
Filling up the Willall trans pan with new fluid
Harmon motive intakes and Willall cooler sitting up front
Willall larger engine sump
New Endless ME20 pads were fitted up front (running MX72 on rear)
Fitted the APP braided brake line kits (front and rear)
    • Be more active mate.. , not taking the piss ❤️, your long term health will love you for it I would think something like a kettle bell or 2 laying around in areas you go past during the day would be awesome for ADHD.... "Oh look, a kettlebell", and exercise helps your brain health as well My mates son was a bit of a problem child, diagnosed wirh ADHD, and some other things that had his brain occasionally doing loops, until we got him into a training program, the difference after he started training was amazing, he had more focus, and his fitness levels exploded, it is like he is a totally different kid to be around Brain chemistry something something Stay fit stay strong mate
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
