yeah sorry we didnt get to catch up. I am not that good with cold introductions so didnt manage to chat with many guys I didnt already know! Regarding the intercooler, I wasnt present for the install (phone pic was from the boys in the shop). I know that the intercooler has made the tuning a little more complex but no big deal otherwise. I will get some info together and get back to you.
thanks Mark. def catch up at the next event.
beaut car. love all the work that has gone into it.
hey what sort of dr are you?
I need to find a surgeon who will do total knee replacements on a 31yr old; no luck so far
last surgeries had my patella's removed, not good for a 201cm tall bloke. loads of pain, disabled now :down:
  • Nope 1
About 20 hp, mostly due to turbulence caused by having it shut rather than extra flow through the side without the muffler as the magna flow muffler is straight through. When closed there is a dead space in the closed section that likely creates turbulence at the y junction.
Cool thanks for the information.
The best thing to note is that with our exhaust (3.5" dumps into a 4" centre pipe with 2x 4" rear pipes) and the willall turbo upgrade, we achieved a BETTER THAN STANDARD boost curve! There has been approx 100rpm gain in boost response which, combined with the extra airflow of the larger turbos, provides heaps more torque in the midrange.
this thing sounds horn! I'm not game to nail it but I can say that by the sound it has it WILL go.
those that have seen it would have noted the camera setup. I had a problem to sort on that this morning.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
