R35 Build
handbrake
this thing sounds horn! I'm not game to nail it but I can say that by the sound it has it WILL go.
those that have seen it would have noted the camera setup. I had a problem to sort on that this morning.
Thanks chris, the setup is awesome. I can't wait to see the fine tuning.
For those that don't know I got Chris to hook up my video box system and output it to the multifunction display. Works really well and is quite practical for car setup/monitoring at the track.
All the wiring and cameras have been nicely installed and wiring hidden so there is no fuss when heading out to the track or running it on the street.
Currently in hospital with wife for the birth of my 3rd kid and only son (he is a little champ!) so won't be till early august that I get the car back out on the track with some more tweaks, can't wait!
congrats Mark. Bugga, I was looking forward to you dishing some more pain on the porka's tomozz.
Haha! Will have to wait until august Noel. Hopefully we can smash the Porsche cup car times then! Look forward to catching up mate.
ok, the car weighs in pretty hefty but htat won't suprise anyone.
1734kg without driver, empty tank and without the rear wing (Aeromotions R2.two about to be installed). this is with the 20 inch HRE's and Bridgstones on them, they are about 0.5-1.0kg per corner lighter than stock.
will see how we go over the few months getting some weight off it!
Congrats on the new bub Mark!
Where abouts are you going to start in getting weight out of the R35? Stripping the interior? getting a Lighter Battery? Driver loosing weight? :P
thanks!
as for what we will be looking to do:
wheels and tyres (track setup already inplace but the above weight is with the street wheels)
seats (remove passenger seat, racetech bucket seat for driver)
Battery
surge tank (purpose two fold - we maxed out the walbro's and allows running less fuel)
stereo, interior trim, carpets
track exhaust setup
CF panels (as the budget allows)
then maybe other creature comforts/doors/dash and sound deadening if I can make the tough decision to go mental or not on such a nice car.
driver will be losing some weight too. about 5kg of sympathy weight gain during the wife's recent pregnancy.
5kg off me probably saves me about $5,000 worth of carbon fibre!
HAhahaha. Too true.
Just loose it with cycling so you have a lower centre of gravity :D
the quality of the bumper looks fantastic, and it definitely looks tough. will see how fitment goes. nice pics showing the ducting either sode of intercooler iopening. hopefully we can make use of these though I suspect things will be tight back there once on!
    • As far as I know, Infiniti stopped importing vehicles before 2020, even though they were still selling their stock for at least a year or 2 after that, they were older build years, therefore, you can import a 2020 400R, because you couldn't buy an AuDM 2020 built Q50 RS. As for insurance, you might need to go through one of the enthusiast insurance companies, they tend to insure a lot more grey import models than the mainstream insurers as Duncan mentioned.
    • loved seeing the zenvo on the a1 just after the hatfield tunnel i was the guy in the white van trying to egg you on it sounded awesome and those exhausts glowing red inside insane cheers for the thumbs up tim and tom.
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
