Nice looking front bar Mark no doubt would have been pretty savage on the bank account although you often get what you pay for. Will be interesting to see how much quicker you can go with some more power and a bit of suspension tuning. I think you might have your work cut out for you trying to better the cup cars time though the thing went quicker again last track day now lapping 54.3. Certainly will be good to watch you have a crack at it though.
Edited by dazmo
sure will be tough but I cant wait to give it a crack! If you don't set your targets high you will always underachieve.
I really need to be sensible about it though, as an inexperienced driver, this thing is now capable of biting me in the arse.
We were running a tune with 535hp, conservative as the guys had literally just finished putting the car together the previous day.
There is a list of mods at the start of the thread, though we used a different radiator (PWR rather than the CBRD)
Hopefully will run about 600hp next time out.
thats awesome.. 54's next time maybe :(
also been wondering, how hard is it to adjust front camber with the hi octane items and how much did they cost.
I dont like the kit i have at the moment as its difficult to change from street to track, then back again.
Best chat to Trent and the guys at mercury. I haven't seen them set the camber in person.
We haven't fully tuned the suspension yet, and went out last time with some rough adjustments. Will have it sorted for the next outing.
The high octane setup is expensive. What control arms did you go with?
Darren, the bumper was actually very reasonably priced. It cost less than many front lip spoilers on there own. It will require some mucking around though when fitting to reposition the coolers to fit perfectly and maximize the use of the cooling ducts/cutouts.
Mark,
Bring your car to Drive Bathurst in November... At least on the mountain you will get to unleash all the cars potential.
Im sure doing 55's around QLD raceway is awesome BUT
Just imagine doing 2.20 - 2.30 min laps around Bathurst...
the beast should be there too....300kph here we come....
Mark,
We would definitely crew for you Mark if you want to go!!
Now we are talking.
Easy - truck the car to Bathurst with Toll Logistics and fly down to Bathurst.
Will be the best 2 days driving of your life guaranteed.
Given we are there 5 days Im having 1000 litres of E85 delivered to the track for 09GTR and myself.
Would be easy to bring you in on this...
You will get to do approx 70-80 laps over 2 days.
Edited by White 35
  • Like 1
so the the guys at mercury started fitting the bumper today. it was a real bitch to fit, not an oem-like fit thats for sure.
managed to get it to line up well in most paces with a lot of swearing, though the fitment at the side indicators is a problem we are yet to solve. fitment at the cooling plate under the hood is a little off also. I will be in correspondence with top racing in the morning to see if there is anything they recommend.
still haven't fitted the air scoops and deflector at the intercooler opening.
sounds like there night be a fix for the fitment issue.
top racing and their manufacturer carbon weave have personally called me 3 times thisafternoon and sent about 4 emails to get on top of the problem. seem very keen to be helpful.
will keep you posted...
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
    • The ones in brackets are the first stages of tightening. I usually aim for the middle of the range. They give a range because it's actually not that critical to hit exactly the right bolt tension. Enough is enough, and too much is too much, and the range given is inside that range. Half of the bolts in the suspension are problematic for putting a torque wrench on anyway, so just get done up to mechanic tight  and spanner checked a week later.
