ok, so I know a lot of people are interested in weights.
so far the car will have lost about 125kg with the following mods:
  • lightweight fibreglass bucket racing seat, both OEM seats removed
  • interior including airbags but excluding dash and door cards removed
  • CF bumper and Aeromotions wing
  • AP rotors
  • 18 inch forged wheels and michelin slicks
I am hopeful we can find another 100-120 kg to remove before adding the cage.
The Racetech seats were too heavy! when you are chasing weight savings every kg counts.
sent them back for these Carbon beauties from OMP (HTE Carbon series) which are half the weight of the others.
installing tomorrow...
midrange torque and power have improved but I am not sure the top end is that much better off currently, still working on it. Maybe Trent can chime in as I havent seen the latest graphs. who knows, might be a different turbo setup in the future.
doors are for weight savings. going for custom carbon door cards and dash to try and knock off another 60kg. also replacing glass
great stuff there :huh:
can't wait to see it at one of these track days. sux that i'm usually working midweek to go out
u're making me spend more money on my car to try and keep up now :) lol
    • Yeah since those first 2 replies I actually went and put some 98 in it and tbf it's already doing much better than the 95 (which is weird and makes my inner tinfoil hat wearer think the 95 was a crap batch), getting 8ish around town. Again, wonder if it takes a while to stabilize if the fuel is changed a couple of times. I swear cars used to just either run "well" or "s**t* in my 20s, none of this fuel optimisation business haha
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
