yes, need to try some new slicks next year to keep up with everyone. so many fast times out there! as always, working on technique and consistency never hurts either.
will hopefully save the second hand tyres for practice sessions.
You not going to put a GTR badge onto the front bumper in the centre there? Seems to be really missing :thumbsup:
Dont worry, will get the badge on there eventually, plenty of things happening with the car. all the carbon is yet to be clear coated.
  • 1 month later...
Just purchased a new beast to tow the R35!
1999 GU Patrol Ti 4.5L petrol jobbie. Damn the diesels are hard to find under 1 million km's
This one has only 14,000 km on the clock, and even smells like new!
going in for a Turbo upgrade with the guys at Mercury Motorsport this week. Thanks guysthumbsup.gif
Then off for a direct vapour injection LPG dual fuel conversion and a new fancy touch screen head unit because I am soft and like my gadgets
Edited by handbrake
  • Like 2
first time out this year on Tuesday 15th so getting a few things ready.
new michelin slicks (28/71-18 front and 31/71-18 rear, man I hope the weather holds out but the forecast isn't looking great.)
Dodson rear control arms.
New set of ME20 endless pads
Have cleaned up the carbon and finally given it a Matte clear coat. It was starting to look a little grubby and was impossible to clean.
Cameron from 'Cameron's bodyworks' sorted me out. really nice guy and good job. Had to use a few different cleaners to sort it out (gun cleaner?!) but it looks better than new!
Wow I always love seeing this car when I go see Trent, Tess and the boys. I actually think when I was in there last week was the first time I didn't see it I knew something was missing.
good to see that nitto had its engine in :D
Im looking forward to seeing this next time im there I hope :D
Also good to see a 35 close to my side of town. :D
interesting Dunc, some say with 'awd' you need to dial camber out in the rear, others say still need 2-3 degrees jsut like the rear whell drive porsche cup cars run.
we have had 1.7. the R35 does have a rear wheel driv bias I suppose
Anyway, looking for more initially, will go for 2.5. pyrometer testing tomorrow will be the answer i suppose (that is if the camber kit arrived as planned!)
many people mentioned 4 degrees up front was unecessary when I bought the front control arms. gotta say I think time has shown 4-5 up front is where you need to be with slicks at least.
I will let you know how it goes.
guys im only running
-2.5 front
-2 rear
and honestly i think its about all you need.
Ive run my GTR at EC, Bathurst, and now Phillip Island (probably done more track time than anyone in Australia at the moment) and unless someone can prove to me with lap time improvements that its worth another 3-5k investment in getting more camber i think you are wasting your money.
If it makes any difference its marginal.
My 19inch Michelin slicks after 3 days at the Island last weekend were worn perfectly evenly and tyre temps were consistent across the tyres all weekend etc.
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
