several things about temperature measurements:
-temperature probes are superior to infrared as surface temperatures may not be representative, especially excessive cooling on the surface relative to the deeper rubber and outer side of the tyre
-outside should be around 5-8 C lower than inside temperatures
obviously noticing excessive wear patterns etc are also a good indicator of correct camber setup for your track and suspension setup.
Yeah Mark agree with you there.
Sorry i meant that all tyres were consistent with each other and yep different temps from outside, middle to inside.
Im running 35-36 hot in the slicks and it actually takes quite a bit of time to get it right.
Im finding that you have to do 3 laps come back in and drop the pressures, then do another 3-4 laps and check them again, possibly let more air out.
Usually after this you can then leave them and they cool down and heat back up to about 35 without having to come in and check them every time.
We need to run our cars back to back!
would love to runa few laps with you guys. I am a beginner for sure so very interested to here everyones setup experiences.
I was running slightly lower psi, around 31 on tuesday, previously about 35 with the second hand tyres. will aim for around 33 next time I reckon. still managed a pb with the new tyres but will be looking closely at suspension tuning for next round.
also interested to hear what temps everyone is reaching on their slicks. I get big variations on inside/ouside of car on our clockwise tracks up here. might end up running a psi or more on the inner tyres to help get the temps up.
  • 3 weeks later...
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
