yes, need to try some new slicks next year to keep up with everyone. so many fast times out there! as always, working on technique and consistency never hurts either.
will hopefully save the second hand tyres for practice sessions.
You not going to put a GTR badge onto the front bumper in the centre there? Seems to be really missing :thumbsup:
Dont worry, will get the badge on there eventually, plenty of things happening with the car. all the carbon is yet to be clear coated.
  • 1 month later...
Just purchased a new beast to tow the R35!
1999 GU Patrol Ti 4.5L petrol jobbie. Damn the diesels are hard to find under 1 million km's
This one has only 14,000 km on the clock, and even smells like new!
going in for a Turbo upgrade with the guys at Mercury Motorsport this week. Thanks guysthumbsup.gif
Then off for a direct vapour injection LPG dual fuel conversion and a new fancy touch screen head unit because I am soft and like my gadgets
Edited by handbrake
  • Like 2
first time out this year on Tuesday 15th so getting a few things ready.
new michelin slicks (28/71-18 front and 31/71-18 rear, man I hope the weather holds out but the forecast isn't looking great.)
Dodson rear control arms.
New set of ME20 endless pads
Have cleaned up the carbon and finally given it a Matte clear coat. It was starting to look a little grubby and was impossible to clean.
Cameron from 'Cameron's bodyworks' sorted me out. really nice guy and good job. Had to use a few different cleaners to sort it out (gun cleaner?!) but it looks better than new!
Wow I always love seeing this car when I go see Trent, Tess and the boys. I actually think when I was in there last week was the first time I didn't see it I knew something was missing.
good to see that nitto had its engine in :D
Im looking forward to seeing this next time im there I hope :D
Also good to see a 35 close to my side of town. :D
interesting Dunc, some say with 'awd' you need to dial camber out in the rear, others say still need 2-3 degrees jsut like the rear whell drive porsche cup cars run.
we have had 1.7. the R35 does have a rear wheel driv bias I suppose
Anyway, looking for more initially, will go for 2.5. pyrometer testing tomorrow will be the answer i suppose (that is if the camber kit arrived as planned!)
many people mentioned 4 degrees up front was unecessary when I bought the front control arms. gotta say I think time has shown 4-5 up front is where you need to be with slicks at least.
I will let you know how it goes.
guys im only running
-2.5 front
-2 rear
and honestly i think its about all you need.
Ive run my GTR at EC, Bathurst, and now Phillip Island (probably done more track time than anyone in Australia at the moment) and unless someone can prove to me with lap time improvements that its worth another 3-5k investment in getting more camber i think you are wasting your money.
If it makes any difference its marginal.
My 19inch Michelin slicks after 3 days at the Island last weekend were worn perfectly evenly and tyre temps were consistent across the tyres all weekend etc.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
