8cms here... worked head stock capacity built 26... 360rwkw @ 20psi... running 21-22psi now not dynoed tho... I'm the T517z on the dyno comparo Ash posted... the Garretts are a much better choice if prices are similar... the Trust turbos are really old truck tech... they hit hard though and will last forever (mine are 8+ yrs old) and cheaper to rebuild should you have to
Hard as they would go with stock head?
Heads not stock, 260 x 9.15 cams and ported and polished.
I have personally seen this car make over 400kw on 3 separate dynos. At the last Time Attack here in SA it was place in the top 3 all day with the exception of the last session. It is making the power.
Edited by D_Stirls
  • 1 year later...
I stuffed a 2530 installing it in my gtr. It took 8 weeks and 1350 to repair. I told them to get f**ked because I was originally quoted up to two weeks and only 400. Went to mtq and got a brand new one for 1350 in two days they also confirmed the cost of repairing as the same. So if anybody thinks they can repair a 2530 for cheaper then that I have a brand new one for sale cheap as f**k just has a f**ked thread on oil feed line hahaha
Is that really all they are capable of with 10cm housings?
Yeah.... it was as hard as they would go on my set up. Stock head (drop in cams), stock exh manifolds, 98 and turns out a questionable exhaust.
I'd take my t517z's over -5's any day.
Only reason I took them off.... I upgraded to bigger twin 'truck' trust turbo's (td06 L2's)...
Garrett sucks..... Trust is awesome!
Awww come on... The little garretts ain't that bad.
Got a graph?
It's a bit rough to say that when Jack did a back to back and the "crappy Garrets" out performed the Trust turbos.
he he he...
The garretts are a pretty good choice....
I ran my T517Z's 7 years ago- they were the best option for me at the time. No graph.
They may out perform on a dyno... but it's hard to argue with 138mph in a full weight r32. havn't seen many -5 cars run those sort of numbers on a stock motor in full trim?
I don't like -5's the same as I don't like 'itard- Apple' products....
So many stories of wayward Gayretts. Have you popped any? I remember at one point you wre looking at grabbing one of Fatz?!?!?
I would say 2-3 out of 5 people I know running Gayretts have had troubles and needed replacing. Both singles and twins.
If you want response go and buy a BB 68 Camaro with screw blower on it! :) Go the Truck turbos. At least when they hit they test the strength of your seat back :)
I have had a few new Garrett's running high boost levels, the main issue with BB cores is they require good clean filtered oil, most of the failures I have seen relate to oil quality issues and oil restrictor blockages.
Bush cores are more resilient to contamination but also require much more oil flow or they will flog out quickly.
My issue was that I stripped a thread putting everything back together. My own fault. Silly Pig!
No no, I'm honestly curious.
138 MPH is hard to argue with, I agree!!!
Why don't you like the -5's? Don't make enough grunt?
-5's are like assholes or iPods..... everyone's got them. They're power delivery is a bit soft for me... they do produce boost sooner, but don't seem to produce 'push in the back' torque any sooner or as much.
T517Z's put a smile on my face in '05.... -5's didn't.
I love turbo cars for the rush of torque when your on the boil... I spent years after trying to chase my ass with the 'ultimate response/power' set up. But when I sat back, stripped it all back and reminded myself why I love my car/s.....
So I started building something that would put a smile on MY face and who gives a siht what any body else thinks.
... what I ended up with is a 2.8, twin billet Trust td06, nitrous injected, dog boxed GTR that makes me crap my pants :yes:
J.
J.
A lot of people have them, no doubt. It's all in the setup though.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
