im jus wondering,
i hve crashed rear part of r34 gtt coupe,
if i buy rear half cut, how much will it cost to stick it on?
n how much is rear half cut? roughly?
if anyone has answer plz pm me or call me on 0410383283,
urgent, atm im driving around with daewoo, so plz info me
https://www.sau.com.au/forums/topic/322601-r34-gtt/
You might as well buy a rolling body and swap all your stuff into it, it'd probably end up costing the same as buying a rear half, cutting your half off, putting it on, aligning it, painting it (probably best to paint the whole car). Lol just buy another car??? unless your a mechanic.
And if you do replace the rear half you should get some wider rear fenders put on at the same time as your already welding and painting the rear anyway
Edited by R34 -_-
https://www.sau.com.au/forums/topic/322601-r34-gtt/#findComment-5261529
yeah someone told me it would be bette,
i wanted to buy quater panel and rear bumper,
thats y i was askin bout,
i think its better to jus straight the boot and buy bumpers n panel,
https://www.sau.com.au/forums/topic/322601-r34-gtt/#findComment-5262069
I've seen a few go for a grand, They'll cost a bit more if they still have bumpers and wheels.
Best way to go would be get a rolling body, i.e only missing engine and gearbox and part out your crashed car, although part of me says to fix your current one as its a lot of f**king around swapping bits and pieces.
Post up a pic of the damage so we can get a better idea
Edited by R34 -_-
https://www.sau.com.au/forums/topic/322601-r34-gtt/#findComment-5262270
i try to upload pics few times it doesnt work,
send me ur email to 0410383283 or leave msg
i will send u the pic thanks
https://www.sau.com.au/forums/topic/322601-r34-gtt/#findComment-5263333
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
    • I left the ceramic coating off this bit, hopefully it just comes off after a few drives.   The gap between the spokes is too tight for anything on a stick, its only marginally bigger than my finger. I have to use a brush to get in there and its a big reason why I thought I'd try the coating.   Absolutely will do. I have EBC Blue Stuff pads to put on the front which will make them a bit dirtier. I'm hoping a pressure wash will just get most off. The shine is different to most, its very thin but seems very well 'attached' so hopefully it lasts.
