Hey people, thought i would just share with you my new system :ermm:
Its a stainless steel, mandrel bent system with ceramic headers, 2.5 inch all the way through :P
Here is the link
cheers!
Thanks man! :)
did you get your resonators removed or have you got any in?
Nah mate got the resonator, and i got everything i asked for, no drone and that disturbing resonating sound that occurs from 2-3k rpm isnt there :ermm:
how much did it set you back if you dont mind?
Not at all mate, it ended up costing me $2200 as i chose to go with stainless steel (more durable, lasts longer), while the mild steel was priced at $1200 im pretty sure. And that price included the entire system including a new cat plus labour :rofl:
cheers people, still only work part time so i had to save for it :) more the fact i had it done stainless steel which made it pricey + didnt wanna go cheapo with a ricer fart can hahaha
Edited by mick2nv
  • 1 month later...
Yeh that sounds sweet as man, i dont want to get a muffler cause it might get annoying but that sounds heaps good only thing is that would clear out my entire bank account and my parents would anally rape me if i did.
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
