  • Replies 260
Yes shame more don`t come out,see S2 silver leave Craig parked next to then ,
& we watch as they drove away :/ ,
but we are in WA not many come to catchup these day`s :thumbsup:
i would have but panna is 1500kms away in the sunny pilbara just south of karratha
Thought id post this up to see if any of you guys were interested in this. Im organizing it through another group im part of. There will be a mixture of cars and bikes. More than welcome to come along.
Planning on cruising to Collie for lunch then cruise back.
Date 15th Aug
Meet Point: Armadale Macca's
Time: 9am
Depart 9:30am
Aiming to be in collie around 12pm
Will be back in perth around 5pm
Total distance is around 400km
Caltex 98 in Collie 175km
Bp Boddington 290km
Jnr
Date 15th Aug
Time: 9am
Depart 9:30am
Bp Boddington 290km
Jnr
I've got a tournament that day and doing a trip to Albany on Friday for a funeral :P
appealing, i saw your stagea on sundee....driving past trigg in a grey 180sx. i beeped. :P
be keen to bring the stagea out on the next one.
We spotted the grey 180sx, didn't know it was driven by a fellow stagea owner!
& we watch as they drove away :ermm: ,
but we are in WA not many come to catchup these day`s :)
Hi Chuckie , Spewin i missed this bin a bit slack on the forum. Cory.
Well we have SA visiter over Ruby & wife are in town for few day`s so maybe catchup one evening might be a BBQ lol,will see what he`s upto & sort something out SO those that may be about POSTUP if your interested & we can set time & place northan Sub`s ok Cheer`s Chuckie.
As Chuckie said, I'll be in WA from friday to monday. Staying at Hillarys area. I'll have a hire car and gps. Should be free most times except during the day on saturday and sunday. In town for a sporting event. Wouldn't mind catching up with fellow stag owners and seeing how the westies roll. :laugh:
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
