Just purchased a 34 and i realised yesterday that the inner 'hotplates' dont light up when i turn the lights - just the two larger outer lights.
Fairly depressing as i want those four lights on at the back!
Anyone have any ideas as to how i can rig them up if need be or if its just a simple fuse....?
Any help appreciated!
Are they standard lights? if there from the factory they should work.. have u or someone else played with them? Only thing that i can think of is blown bulbs but what you said, to me sounds like your lights have been modded or something, maybe damaged????
They've been rewired for compliance. You'll need to reverse it again
Not even that, that's how they come from factory. The inner lights use 2 x T10 bulbs to illuminate. You can't buy a T10 bulb with brake light function dual filament
The outer light uses a single T20 (7443) type socket with brake light function dual filament.
So without some major changes, that's how they are I'm afraid.
You can wire them so the T10's come on at the same time during the day, but at night you will only get the outer ones change in brightness.
guys - took the lights off the other night, there was some dodgey as wiring going on! I wiggled the buggers then they worked! Soldering iron and crimper fixed that crap - all sweet now :P
