Hi all,
I have 33 GTR.
It have the following performance modifications;
- HKS Pod filter.
- HKS front pipe (3" to cat).
- 3" Gutted cat.
- HKS 3.5" cat-back exhaust.
- Boost restrictor removed.
Last night, my friend and I noticed something strange. 4,000rpm, it make whistling sound and when it's warmed, it is struggling to build boost. I left it to cool down for couple of hours then drove home, I have no issues building boost to 14psi, after 20 minutes it was struggling to make 1-3psi.
Tried this morning, it did the same then turned the car off for 5-10 minutes, got boost but didn't drive further to really check it again.
No white/blue smoke coming out of exhaust.
I still have oil pressure, and it is behaving like it should.
Checked all the clamps, but after doing some researching it appears the vaccum hoses may be the culprit?
I think the rubber hoses (afm to turbo or FMIC piping) may shrink from the sucking air from the turbos - which may be the case seeing the GTR is 14 years old?
I'm not sure if the air is leaking - I'll need someone to try to hear it for me (I'm deaf so can't hear zip).
Haven't checked the exhaust yet, but someone mentioned exhaust manifold gasket so will check it out.
Any ideas or suggestions?
Godamn GTR!
Thanks in advance.
Grant
https://www.sau.com.au/forums/topic/322732-what-did-i-break/
Anyone know the cause or you're as stumped as I am?
i think your car just gets the shits every time you take it for a sau cruise because it knows your going to give it a hard time and decides to break something guess who is off to see trent again
I think you're into something there...
On the bright side, I didn't need tow truck this time, pretty rapt about that to be honest.
Hi all,
Just had someone PM'd me saying the hose or clamps has split so anyone with 33R have hoses in good nick to sell to me so I can test it?
I have someone coming by to have a listen for me later this arvo just to be safe.
Cheers
Grant
Hi all,
Cheers
Grant
That would be my guess, when i split a hose it would still slowly build boost till about 12psi then it would start misfiring and spitting out black smoke, was about 100k's from home so i tried wrapping it in duct tape, didnt work all that well but was enough to get me home.
Hi all,
John (ssxRicho) dropped by to have a listen, he said he heard loud screeching but all piping and clamps look to be fine.
We went for a drive and see if it is happening, it didn't struggle to build boost.
Only difference between yesterday and today, yesterday I drove roughly 600km and today, about 30km if any (not continuing though).
Could it be a sign of turbos is on way out even though it is driving just fine, no white or blue smoke coming out of exhaust.
So I'm puzzled once again, stupid GTR. So off to see mechanic for another opinion.
Cheers
Grant
My gtst had a screeching noise which i thought was the turbo, havnt taken anything apart yet but i have notice a couple of exhaust manifold studs are missing, check those first.
To do that, I'd have to literally dismantle the motor. And while I'm at it, I may as well buy new turbos.
I wish I still kept my old GTST.
you cant see the manifold studs with out taking the turbo's off?
Im talking about the ones in the head not the turbo ones, although it could be them as well.
Yeah, can't really see without removing twin turbo pipe.
Manifold studs that break, are they usually on top side of the manifold or bottom?
Being time dependent means it is heat dependent, meaning its an exhaust component before it is an intake component.
If it were a split in your cooler hoses it would occur from word go.
Although, I had this issue happen to me a long time ago on my fwd SR20. After it was driven for a while it would begin shrieking on boost like you wouldnt believe... and it would struggle to boost properly. The cause; turbo to manifold gasket.
I wouldnt go ripping your turbos out without looking for evidence of carbon stain in that area first.
GL
Scott,
What is the best way of finding the carbon stain in crowded engine bay as found on 33 GTR?
I think I'll get new clamps and tear the whole front end to replace them, see what happens after that.
Cheers
Grant
did mine today 2 at the rear 1 at the front were cracked...i initially noticed loose nuts and went to tighten the nuts and one just fellout in my hand..3 cracked in the head..as well my turbo bolts were loose...seems to be common problem on gtst not sure about gtr...Im thinking the same maybe its an excuse for a new turbo...Good luck with it..
Yeah, it is 14 year old so it happens.
It's bit of a bad timing considering I sold my perfectly good pair of HKS 2510s that I was going to put in my GTR, so will need to go turbo shopping...
Like I said earlier, I'll change the clamps and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
