Hi guys.
I am wondering what would be the safe boost level to run on a RB25DET NEO (ER34) with stock internals. I am boosting at 1.3bar (18.8psi) with stock internals and a 1.3mm metal gasket. Is that safe and reliable? Btw, I have no knocking issues as shown on the PFC.
What would be the threshold before the insides have to be upgraded.
The search button is not invisible. It's at the top bar incase you haven't try to use it to search. I have.
There are way too many differing thoughts via the search. Some say 300rwkw some say 400rwkw.
I am not running GT62. I am on HKS GT-RS but the question is not how much boost can the turbine take. It's how much boost/power can the stock internals handle.
Thanks for your reply.
The reason you won't get a good answer is due to almost no one knowing what your in cylinder pressures are during combustion.
The amount of "boost" is a fairly moot point providing you have good tuning.
A HKS GT-RS will not exceed the internals.
fwiw i run 17psi with stock motor and stock HG. runs a 3076 with highmount manifold and all the supporting mods, makes around 300 rwkw and does it reliably as hell
X amount of boost doesnt = limit of an engine (to a degree) as its certainly safer to run 16 ish psi thro a larger turbo then it is running 16 psi thro a stock turbo where its past the efficency range.
with a decent turbo/tune/supporting mods theres no real reason why you cant make 300 rwkw+ all day every day
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
