hey guys and gals, bit bored at home so though id post this timeline of my cefiro and r31
ok so after the r32 re-furbish sorta went down the drain as u can see
after parting out the 32 i had about 10k to play with so i bought this
it had busted JIC coilovers, blitz catback and a pod filter, id planned to keep it stock with just some wheels and lower it, but after the coilovers gave in the mods started and this is what its come to
1988 cefiro
engine:
rb20DET
HKS 25/35 turbo rebuilt by RotaMaster
JJR 38mm external watsgate
Supertech forged pistons 20thou oversized
ARP rod bolts
ARP head studs
Cometic metal head gasket
Cometic gasket kit
nissan oil pump
nissan water pump
nissan idler pully
nissan tensioner pulley
NDC bearing kit
HKS camshafts, 264/8.5mm
HKS cam gears
Gates timing belt
Tridon thermostat
crank was grub screwed, balanced and ground
balanced pistons
balanced and resized rods
block was decked, bored and honed
resurfaced head
valve grind
new valve stem seals
exhaust guides and ports cleaned up a bit
braided lines
Hypergear front mount kit
Gkteck dump and front pipe
Blitz cat back
Splitfire coilpacks
JJR alloy radiator
JJR silicone radiator hoses
R33 GTS-t air box
z32 AFM
GTR injectors and resistor pack
Status remaped ECU
Walbro fuel pump
custom metal intake pipe
Blitz sandwhich plate
JJR oil cooler kit
gutted cat
GReddy water temp sensor
RedTop RB20 rocker covers
battery relocated to boot
fuse box relocated under the dash
driveline:
5speed manual
Jap spec Excedy 3 puk ceramic clutch
Nismo 2way lsd
lightened C33 laurel flywheel
Redline shockproof gbox oil
brakes:
r32 twin piston front calipers
r32 front discs re drilled to 4stud
s15 rear hubs
stock rear discs re drilled to 5stud
BM44 brake booster
Cusco BMS
suspension:
Whiteline adjustable rear swaybar (27mm)
JJR front swaybar (30mm)
JJR solid steering shaft bush
TuneAgent castor arms
JIC camber arms
JIC FLT-FAS coilovers
JJR solid rear cradle bushes
JJR rear strut brace
Cusco front strut brace
JJR front under car brace
ISC rear toe arms
ISC rear traction arms
interior:
GReddy boost guage
Defi oil temp/pressure and water temp guages in DIN slot
JJR drift handbrake button
GReddy turbo timer
Bride drivers seat
Bride centre console
R32 passenger seat
Cusco C33 laurel rollcage
Nardi 350mm deepcorn
GKteck boss kit
rx8 gearknob
Factory Nissan floormats
Kenwood headunit
JBL front and rear speakers
train hang ring
deleted all a/c related parts
fire extinguisher
exterior:
Autech body kit
Nissan factory weathersheilds
late model "laurel style" chrome grill
roof spoiler
R34 GT-t rear windscreen wiper
GKteck bash plate
wheels and tyres:
front:
17x9.5 +5 SSR Professors with 215/40 Federal 595s
rear:
17x9.5 +22 SSR Professors with 235/40 Federal 595s
Rays wheel nuts
https://www.sau.com.au/forums/topic/322765-kriss-a31-cefiro-and-r31-4door/
then this happened, sandwhich plate wasnt on properly and dropped all the oil while i was running in the motor, f*ked the head and exhaust cam and thats pretty much where im at now, motor is out again and is getting the head fixed and ive got another hks cam from japan
It looks like it comes up a little higher than my manual console (yes, mine isa proper manaul console, not an auto turned manual console)...maybe I'm just tripping out? Mine is black, and its covered in all sort s of shit in a dark shed so it probably naturally looks smaller....
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
