hey guys and gals, bit bored at home so though id post this timeline of my cefiro and r31
ok so after the r32 re-furbish sorta went down the drain as u can see
after parting out the 32 i had about 10k to play with so i bought this
it had busted JIC coilovers, blitz catback and a pod filter, id planned to keep it stock with just some wheels and lower it, but after the coilovers gave in the mods started and this is what its come to
1988 cefiro
engine:
rb20DET
HKS 25/35 turbo rebuilt by RotaMaster
JJR 38mm external watsgate
Supertech forged pistons 20thou oversized
ARP rod bolts
ARP head studs
Cometic metal head gasket
Cometic gasket kit
nissan oil pump
nissan water pump
nissan idler pully
nissan tensioner pulley
NDC bearing kit
HKS camshafts, 264/8.5mm
HKS cam gears
Gates timing belt
Tridon thermostat
crank was grub screwed, balanced and ground
balanced pistons
balanced and resized rods
block was decked, bored and honed
resurfaced head
valve grind
new valve stem seals
exhaust guides and ports cleaned up a bit
braided lines
Hypergear front mount kit
Gkteck dump and front pipe
Blitz cat back
Splitfire coilpacks
JJR alloy radiator
JJR silicone radiator hoses
R33 GTS-t air box
z32 AFM
GTR injectors and resistor pack
Status remaped ECU
Walbro fuel pump
custom metal intake pipe
Blitz sandwhich plate
JJR oil cooler kit
gutted cat
GReddy water temp sensor
RedTop RB20 rocker covers
battery relocated to boot
fuse box relocated under the dash
driveline:
5speed manual
Jap spec Excedy 3 puk ceramic clutch
Nismo 2way lsd
lightened C33 laurel flywheel
Redline shockproof gbox oil
brakes:
r32 twin piston front calipers
r32 front discs re drilled to 4stud
s15 rear hubs
stock rear discs re drilled to 5stud
BM44 brake booster
Cusco BMS
suspension:
Whiteline adjustable rear swaybar (27mm)
JJR front swaybar (30mm)
JJR solid steering shaft bush
TuneAgent castor arms
JIC camber arms
JIC FLT-FAS coilovers
JJR solid rear cradle bushes
JJR rear strut brace
Cusco front strut brace
JJR front under car brace
ISC rear toe arms
ISC rear traction arms
interior:
GReddy boost guage
Defi oil temp/pressure and water temp guages in DIN slot
JJR drift handbrake button
GReddy turbo timer
Bride drivers seat
Bride centre console
R32 passenger seat
Cusco C33 laurel rollcage
Nardi 350mm deepcorn
GKteck boss kit
rx8 gearknob
Factory Nissan floormats
Kenwood headunit
JBL front and rear speakers
train hang ring
deleted all a/c related parts
fire extinguisher
exterior:
Autech body kit
Nissan factory weathersheilds
late model "laurel style" chrome grill
roof spoiler
R34 GT-t rear windscreen wiper
GKteck bash plate
wheels and tyres:
front:
17x9.5 +5 SSR Professors with 215/40 Federal 595s
rear:
17x9.5 +22 SSR Professors with 235/40 Federal 595s
Rays wheel nuts
https://www.sau.com.au/forums/topic/322765-kriss-a31-cefiro-and-r31-4door/
then this happened, sandwhich plate wasnt on properly and dropped all the oil while i was running in the motor, f*ked the head and exhaust cam and thats pretty much where im at now, motor is out again and is getting the head fixed and ive got another hks cam from japan
It looks like it comes up a little higher than my manual console (yes, mine isa proper manaul console, not an auto turned manual console)...maybe I'm just tripping out? Mine is black, and its covered in all sort s of shit in a dark shed so it probably naturally looks smaller....
