nismo 2way lsd centre 6 bolt suit s14,ect$500
6bolt drive shafts$100
25mm wheelworx 4 to 5 stud spacers $450
r32 diff,cradle,shafts,all arms,$300
slip on 4 stud 5mm spacers $20
link r20det ecu direct plug in $400
rb20det injectors $50
r32 left hand indicator $30
r32 left hand head light $50
r32 rb20det ecu $100
rb25 crank angle sensor $80
walker 2inch cat brand new $50
walker 2inch muffler brand new $50
rear cannon 2inch inlet 4inch outlet brand new $50
r32 window switch ass$50
r32 rear hubs,rotors,calipers,ect $250
uras cefiro front bar $150
rb25 top and bottom half of intake manifold $50
rb20 cam cover $15
r32 left hand door black,with window$150
cefiro front seats $50
r31 s3 head lights$40
31 s3 bonnet silver$80
31 sedan doors silver,with widows $30each
31 s3 boot $50
s3 taillights $40
s3 tinted back $60
s3 front bar$40
brand new 2jz water pump$100
SA STRATHALBYN 0431 540 141
hey dude yeah it will fit 33,32,cefy,s13,14 as far as i no
R33 is has 5 bolt drive shafts... You can't use your own half shafts either because they are different length to the nizmo ones...
Can anyone confirm whether the s14 driveshafts are the same length as r33? To do a full 6 bolt driveshaft conversion lol..
I'm interested in the r32 left indicator and r32 driver window switch ass if they're still available.
Does the window switch work fine?
the idicator is all orange not a clear,just to let you know.yeah widow switch works fine.
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
