the idicator is all orange not a clear,just to let you know.yeah widow switch works fine.
ok. Didnt end up needing the indicator, but still interested in the window switch.
Is $40 + postage ok?
is the link ecu just a remapped unit , or is is live tuning enabled?
i think it live tuneing do u want more photos link is printed on the actual board and all the chips
Is the diff complete in a housing? whats the diff ratio too? thanks
nah theres a pic on first page, it the centre half shafts and drive shafts,cost me $750 and havent even used it,it done about 13,000km from new my mate bought it new,never been to track
hey chris , how you doing man , just wandering if you still have that uras cefiro front bar lying around ?
let me know asap man
thanks for your time
cheers anf
hey mate
Have you got the pc cable, map sensor, anti static strap, and all the gear you get when you buy a link ecu new?
nismo 2way lsd centre 6 bolt suit s14,ect$500
6bolt drive shafts$100
25mm wheelworx 4 to 5 stud spacers $450 SOLD
r32 diff,cradle,shafts,all arms,$300
slip on 4 stud 5mm spacers $20SSOLD
link r20det ecu direct plug in $400
rb20det injectors $50SOLD
r32 left hand indicator $30SOLD
r32 left hand head light $50SOLD
r32 rb20det ecu $100SOLD
rb25 crank angle sensor $80
walker 2inch cat brand new $50
walker 2inch muffler brand new $50
RB25 cam covers$40
rear cannon 2inch inlet 4inch outlet brand new $50
r32 window switch ass$50
r32 rear hubs,rotors,calipers,ect $250
uras cefiro front bar $150
rb25 top and bottom half of intake manifold $50
rb20 cam cover $15
r32 left hand door black,with window$150
cefiro front seats $50
r31 s3 head lights$40SOLD
31 s3 bonnet silver$80SOLD
31 sedan doors silver,with widows $30each SOLD
31 s3 boot $50SOLD
s3 taillights $40SOLD
s3 tinted back $60SOLD
s3 front bar$40SOLD
brand new 2jz water pump$100SOLD
SA STRATHALBYN 0431 540 141
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
