Hey guys, ive searched the forums and cant find a topic on this so sorry if there is one already
i am hopefully purchasing my first skyline :down: . I have found an R32 GTS-T for a really good price and have worked out insurance if i do chose to buy it.
i am a huge lover of the R32 but money is fairly tight and i was wondering how reliable the car will be as it is 20 years old :happy: i am getting a trusted friend who is a respected mechanic to look the car over with me but i am asking you guys who own similar cars. should i expect it to break down every week and cost me an arm and a leg to fix or should it run well as long as i look after it (which i will as i have a huge respect for cars in general haha :) )
so yeh any feedback would be great before i let my emotions take over and just hand over the cash :D
thanks in advance
Brendan
https://www.sau.com.au/forums/topic/322849-r32-reliability/
My 32 gtst has never left me stranded (came close a couple of times.. snapped the clutch pivot once and another time split a heater hose) but being 20yo, you're going to have to expect that things are going to start needing replacing.
I think the major costs that *could* be involved would be replacing all bushes/wearing suspension components.. if the engine dies then a 2nd hand RB20 isn't very much but replacing all the bushes etc can be very labour/time intensive.
https://www.sau.com.au/forums/topic/322849-r32-reliability/#findComment-5264773
only advice that i can give is from experience with my 1989 180sx (not a skyline, but from same era and similar build).
what i noticed is that when stuff starts going (like radiator hoses) it's a good indication that other similar items are going to fail. ie when one radiator hose goes, get them all changed. i went through all the hoses on my engine in like 6 months, one breaking after another. so basically it's worth doing things properly once :happy:
but if the previous owner(s) have respected the car then you will be fine. so things like not pushing it until the engine is hot etc.
https://www.sau.com.au/forums/topic/322849-r32-reliability/#findComment-5265235
thanks for the reply's guys :happy:
ive heard and reseached and stuff and they seem pretty tough. i just wanted to check from actual owners as to how they are. i will hopefully be buying one soon then:) as all ive heard is good things.
ill definately drive it gently haha. they dont deserve to be thrashed as they are amazing machines:)
thanks again
Brendan
https://www.sau.com.au/forums/topic/322849-r32-reliability/#findComment-5265243
its a second hand sports car which has been driven like a sports car in japan and in australia.
If you expecting the same reliability as a family toyota corolla then you might be surprised.
Regardless if it is a skyline, any second hand sports car will require maintenance. What you should be looking into is the costs when things break, because thing will break.
Luckily for skylines there are plenty being destroyed by kids and there are plenty of spare parts and aftermarket parts floating around.
So once something goes pop it is quite easy and cheap to find a replacement part from Nissan Australia, skylinesaustralia or an import wrecker.
Plenty of r32 parts can be interchanged with r33's (starter motor, alternator, clutch) and GTR's (coilpacks, injectors *with some rewiring) etc
https://www.sau.com.au/forums/topic/322849-r32-reliability/#findComment-5265338
  • 2 months later...
I had my R32 GTS-t for about 5 years and it served me pretty well. I gave it slightly more frequent than usual servicing which kept in top condition.
It was well modded and I tracked it at least 3-4 times a year but it was also a daily car for me and I'm normally a very sedate driver. It never really gave me any grief aside from the usual RB engine hassles like the Coil-packs failing and the turbo manifold gaskets and bolts breaking.
I would also say the suspension arm bushes given that the car has double wishbone suspension all around they need to be replaced as mine started to rattle quite a bit and affect camber during cornering.
But those are really things from wear and tear due to its age. Those items mentioned above you'll only have to do like once every 6-8 years depending on how you drive it.
But like everyone else says it is basically a money pit and now that I've moved to a GTR. In comparance I kinda miss the simplicity of the GTS-t. Both cars are really reliable though. But I'd say the GTS-t was cheaper and easier to fix.
https://www.sau.com.au/forums/topic/322849-r32-reliability/#findComment-5400864
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 馃槈. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 馃槏.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 馃檹 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 馃槈. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 馃槏 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
