Dyno tune will be a while still when I'm ready to adjust the cam gears.Until then its road tuned
N1GTR.. Technically the only thing new about this is the actuators, and I'm sure if you purchaced -9 from gcg etc. they would put on the same 8.8psi actuator like what I got. Otherwise, same -1 / -9 / Gtss unit.
I think response can be tweaked further with the tune and also with boost control as there is no creep and very minimal spike(1psi) as is right now, so definately some gain to be have there, even if minimal.....and then there are cam gears
Have only been driving it a few days, but it does pull a touch harder on 13psi, But so far I'm satisfied that I have turbs capable of 300rwkw with stock like response.
Aaaaaah my bad!
Here's what I thought you meant;
http://www.turbobygarrett.com/turbobygarrett/products/turbochargers.html#medium
GT2854R - 471171-9
GT2859R - 707160-9
GT2859R - 780371-1
GT2860R - 707160-5
GT2860R - 707160-7
GT2860R - 739548-9
GT2860RS - 739548-1
GT2860RS - 739548-5
GT2871R - 472560-15
GT2871R - 743347-1
GT2871R - 743347-3
GT2871R - 707160-10
GT2871R - 780371-2
GT2871R - 743347-2
GT2871R - 743347-4
GT2871R - 771847-1
GT2876R - 705330-1
GT2876R - 705330-2
This is the last dyno tune I had, -9's, nismo pump, 555cc injectors, nismo AFM's, cam gears, stock engine.
Figures in all wheel killerwasps.
Since then I have fitted a different boost controller and the wastgates are now set to open at 16PSI with controller off.
Needs another tune to set boost controller and get rid of the drop in boost pressure. 22PSI tune to follow.
I'll let you guys know....
Aaaaaah my bad!
http://www.turbobyga...ers.html#medium
GT2854R - 471171-9
GT2859R - 707160-9....Gtss
GT2859R - 780371-1....Gtss with act
GT2860R - 707160-5.....2530
GT2860R - 707160-7....R34 N1
GT2860R - 739548-9
GT2860RS - 739548-1
GT2860RS - 739548-5
GT2871R - 472560-15
GT2871R - 743347-1
GT2871R - 743347-3
GT2871R - 707160-10....Gtrs
GT2871R - 780371-2....Gtrs with act
GT2871R - 743347-2
GT2871R - 743347-4
GT2871R - 771847-1
GT2876R - 705330-1
GT2876R - 705330-2
:thumbsup:
I guess they didn't say anything about injector duty.
I was seeing roughly 90% on a cold night with 22psi peak in the midrange through to 17psi or so at the top end. Rich enough to see black out the back on full boost :whistling:
Stock fuel reg too....
Should be okay, guess I'll find out.
Well since there is NO info on this here I just thought i'd put this up and update as I go along.
The comparision below is results for the -1 turbo which is the -9 that comes with a 8.8psi actuator from Garrett, compared to stock R33 Gtr turbos.
The top window is the -1/-9 which reaches the same level of boost(13.3psi) about 200-300rpm later than the stocks, and the car drives basically the same as before.
The ONLY thing changed was the boost level was raised only one notch on the controller (profecb2) to get the same level for comparision....start/gain etc was left the same and the pfc tune was untouched.
My boost control kit reads 1psi low for some reason, hence 13.3psi
Ignore the scale on the bottom as this would be different due to the length(secs) of each log
Well with two turns in on the actuators I was able to get it down to stock like response, well on paper at least....To me it feels even better than stock coming into boost
Top -1/-9, bottom is stock
Is boost creep the only thing to look for with too much preload? I want to shorten them some more :yes:
    • That specific one would be an exchange part, meaning I'd have to send mine to them. Plus it looks like a non AWD sump, which won't work for me. There is one or two shops in my country that I can ask to do a sump extension job and it'd most likely end up being cheaper than sending mine to AUS or NZ and getting one back, and quicker too.
    • Rear turbo is leaky, most likely at the oil drain. From what I could see with my boroscope it seemed to have seeped out at the very top of that return hose. Is it possible that the oil climbs up that hose to then leak out? Yup, coolant leak on the hot side of the engine, only noticed after seeing clear rusty residue in the block right from the turbo oil feed downwards to the pan, and red droplets hanging from the pan. No clear sign yet from where it comes, and most of the lines there are hardlines right? Last year, seeing those red drops, I thought it was power steering, will be glad if that is not leaky at least. Another leaking hose I found by chance is the lower of the two heater core hoses coming from the firewall to the back of the head. That one is not too bad to get to if I have to replace.
    • I think for response I'm already kind of out there no? he -5s are not the best pick for that as the Internet tells me. Maybe I should switch to -7s while I still can? Though that almost definitely warrants an engine pull along with the other issues I have.
    • Which I agree with. I don't want or need a high hp straight line car, I want it to be fun on the road and nothing more. Hence why I said my max power goal will be around 500 crank. The few times I drove the car last year I didn't even use high boost and it was already quick enough for me, should have been around 380-400 crank I think (2860-5s at 1-1.1bar).
