Garrett Gt2860 -9s
Thanks guys,anyone run 300kw with -5s on a 1/4 mile with a time?
No one would buy -5s and run 300rwkw. Added lag for... What?
They are 360rwkw+ turbo, so you run them at 360rwkw... OR buy -7s if you want 300rwkw, or -9s if you want 330rwkw
Given that is what 7 pages of this thread is about, not to mention the other threads...
I understand the lag on the -5s but i was more wanting to know 1/4 miles times both -5 -9 running at 300kw.
The reason i ask is im running a stock bottem end and slowly building a motor to run 380plus kw and i dont want to buy -9 or -7 for 300kw an selling it of 1 year later for half the price,i do want to swap the -5 on to the new built motor chance its completed,there are numbers of people running 300kw even less on -5s,im on a very strict budget,and dont mine the lagg to save some $$
Edited by nitestage32
Not sure, maybe you missed this?
It'll be about the same. 300kw is 300kw.
Torque also plays a factor but for the most part it'll be close enough for the sake of the argument.
Same shit dude. It's not an issue of importance or one you will EVER get an answer to.
Car weight, driver, tyres etc - all far more important variables to worry about anyway.
Oh and if you are on a strict budget, hate to tell you but you'll end up blowing it. No-one meets a tight budget when doing a full build. It's just impossible as there are too many variables that again come into play.
I don't get your point for, sounds like you want -5's just so you can say you have them, if you don't mind the lag why not aim for 400kw? If not go smaller. Your desicion is 300kw lagy or 300kw responsive....simple choice
He is slowly building his motor so running 300kw's with the -5's for now, and then when the motor is finished being built he will go for a higher figure :thumbsup:
    • There are fixes for this. In industry we use compressed air for everything. It is frequently wet, and many things cannot tolerate it. So there are various forms of driers available that you can install. The simplest option for something like this would be a dessicant drier. Much cheaper to replace some silica gel than actuator cylinders.
    • That's a solid update mate, well done at WA FOS. You may already know this, but the actuators on the paddle shift are a service item and are sadly not that reliable. As I understand it they collect water from the compressor (condensation) which then rusts the bores/pistons in the actuators. A mate of mine had no end of trouble with them in one if his circuit cars, apparently it's a 'known issue'. Buy a couple of spares at great expense to ensure you never have any problems with the ones you've got! Any clues about what the new WTAC rules might be? While faster cars are cool the Pro class arms race has got to the point where you wouldn't even bother entering without a $1m budget and even then I don't think you'd win.
    • https://nissan.epc-data.com/skyline/er34/3945-rb25det/trans/317/31940N/ The pictures of the part you're talking about is clearly not just one solenoid. You can see another picture of it here: https://www.alltranz.com.au/shop/drivetrain/automatic-transmission/RE5R01A/product/9305/ The 4 speed automatic in the GTT is Nissan corporate stuff. You can search up similar jobs done on a Frontier or Pathfinder with a RE4R01B to get an idea for what the internals are going to look like and the procedure like this:
    • Hi Chris,   long time since your post, just wondering if you have the Pinout for the v35 stereo plugs, I bought the roem nis2 harness but it doesn’t match the v35 connector. any help appreciated, I can work out the grn and power constant. But the rest might be hard. thanks Tyson
