10 psi!!!! Jesus.
For sure will be looking at new dumps in the future. But I wish to enjoy the new found power. Besides it keeps me interested in the car if there is always something to do. :)
Are you running mafless?
I'm running twin Z32s with stock airbox
Haha don't worry you will find plenty to do to the car if you really look ;)
  • 3 weeks later...
http://www.gtr.co.uk/forum/96210-5s-7s-7.html
Just read all 13 pages, not to much mention of the -9's though they seem to have a totally diffrent opinion on -5's.
Main jist here seems to be -7 or -9 with stock motor, -5's for a storked engine.
Yet they are claiming to be making boost by 2000RPM and on song by 4k. Non stroked motors.
a few posts from a couple boys here aswell
Also don't forget that thread is quite old for the most part (2008 etc). There won't be a lot of talk of -9s as they didn't come onto the market until ~2008/2009 IIRC as they were still under the HKS GT-SS banner and expensive, and then Garrett released them etc.
I mean claims in that thread that -5s are "really into it" by 3000rpm are just plain silly. That same user then posted a graph - 4000rpm not even 170rwkw ... lol... really if that's "into it", i'd be worried. :rolleyes:
Yes they might be building boost - but in 4th gear it'll still takes you longer from 3000rpm-4000rpm than it does from 4000rpm-8000rpm on a 2.6ltr, once the turbos are well into their sweet spot and the motor is working.
End of the day it comes down to ones 'definition' of what is/is not laggy. Turbos that come on @ 4000rpm-8000rpm for ~370rwkw or turbos that come on @ 3300rpm-7500rpm for ~330rwkw
Basically the same power band - just totally different delivery & RPM use. Then there is also response onto boost in/out of gears, on/off throttle etc.
End of the day - do what we've told you. Jump in the passenger seat and see for yourself and what you prefer.
  • 3 weeks later...
Ok, Sifted through the rb26 turbo upgrade thread,
Looked at all -5 and -9 setups with similar mods ect
-9/hks gtss
3k rpm= 130kw
5krmp= 254
100km/ph= 16kw
110km/pk= 130kw
-5/2530
3krpm= 85 kw
3krpm= 100kw
3390rpm=80kw
5400rpm= 200kw
100km/ph=100
100km/ph=110
110km/ph=140
Not many -9/gtss examples, Though
Taken a while to sift through it all, So i thought id post this up for reference to anyone else making the choice, These are all on a std 2.6 capacity
Was actually going to go against everyone's comments and get -5' this week. But this proves the -9s shit all over there bigger brothers, Unless you plan on doing ridicules speeds.
Dude, are you still trying to make up your mind?
man you just need to take the plunge and go and get whatever your goal is.
Is your goal 300-350kw? -9's
is your goal 350 - 400kw? -5's
Done, go spend your money
wish it was that easy....the KW range is not my goal. Although it easier to strive for a particular figure. Now im more looking at the driveablilty.
All fair and well to say you have 400kw....but its not very practical to have that at 150km
Main reason for me doing this is to compare the power at the lower range. And to me it looks like the smaller set up has alot more usable power. ( if ive read then all correctly)
ive taken the time to post my findings for people in the same position in the future...Dont see the big deal?
Nah thats not the problem. What is working on my nerves is, we have said countless times, if you want it power sooner ie boost sooner, then get -7's or -9's and they will yield 300 - 350kw!
If you dont car about lag and your car is not a daily and you want peak power then get -5's and once again, they will yield 400kw's.
I see no fine print in this, it looks very straight forward to me.
Nah thats not the problem. What is working on my nerves is, we have said countless times, if you want it power sooner ie boost sooner, then get -7's or -9's and they will yield 300 - 350kw!.
has anyone actually got 350kw from -7's or
9's
I think someone did 360rwkw, but it's never been repeated (or confirmed).
Common is 320-330rwkw realistically and what people should expect.
+1 to comments thus far. I'm kinda sick of getting PM's about the same topic & questions :unsure:
    • Yep that's a superb price and ther is no way you will over capitalise on you investment.  As to the bracket, again just use the passenger side seat  bracket ( obviously reversed ) as a sample to reshape it and in this case, TIG it back together.
    • Thanks for that.... If only I could do something once and be happy with that, like some people do....
    • I had no transmission at all so I managed to find a big box manual gearbox from an R34 GTT for an insanely good price in EU. I converted it to push type which cost more than the transmission almost, with parts from Amayama! These engines are very strong and can put out decent power with a properly sized turbo. You can save on money from parts like pistons and rods, and invest those in the transmission and other parts. I suggest you join the RB20 Enthusiasts facebook group, plenty of info and almost daily posts there about 20DE/DET/Neo+T builds. (I hope I'm not breaking any forum rules by mentioning third party platforms, just trying to help the buddy out)
    • Yeah, having tried all of those methods including BBQ+recipro/hacksaw, I ended up buying a bush press kit under $150 that works well, like this: https://www.ebay.com.au/itm/355967727167?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=sfmmuhxgqhm&sssrc=2047675&ssuid=dJvnaZ11TB-&widget_ver=artemis&media=COPY It basically has a range of pushers and cups with threaded rods between to press out a range of large bushes. The problem with any sawing solution is minimising damage to the subframe side, although it probably needs a quick sand afterwards no matter what solution you try due to damage
    • Hi. Thanks for the answer. I do not have instagram 😄 I too considering turbo the RB20DE NEO 🙂 But i think i upgrade the gearbox first or at least buy new.
