Take care of michaels car :thumbsup:
good friend of mine
So bro, (op)
What happened to making the decision yesterday?
You have all the information in the world. All of us have elaborated so much in this thread, that you should know by now what you would much rather want.
Have the invoice on my work desk. Will be paying for a set of -9s first thing tomorrow morning
good friend of mine
Ahh thats the michael u mean. Bout to start swapping his turbo's over. Then injectors and a tune. Should make a little bit more than the 210kw he has at the moment
No Greddy dump/front pipe extension. Standard AFM maxing and I didn't want to push past it. I'm happy with what it makes and it pulls like a f**king train all the way to redline. Thinking of going Nismo AFM later and playing with the cam gears a bit more to make it more responsive, while making a bit more power.
Which is what I don't have. Need to sort out a big 4" high flow cat or something.
You should be into the 300s with 19psi
That would be choking your setup and a quick simple install and retune and car will feel
Even better
  • 1 month later...
Okay, bumping up this old thread!
-9's look like the best for the response.
However, if someone was to go -5's and threw in some Tomei Type R cams, would we still be talking about this huge lag?
I'm pretty new to this, but I would think a set of cams built for response could indeed reduce this lag? Maybe even Mine's cams hehe
You simply won't be able to to put cams in to combat the size of the turbos when talking about those two choices. Yes that big difference in lag will always be there although you may reduce it by a bit It's not going to go away completely and won't ever be equal between the two turbo choices
A set of -9's and low duration cams would be heaps for the street.
Larger cams will not magically give you 500rpm better response on the street or on/off throttle.
  • 2 months later...
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
