Means that HKS have done more then just put their actuators on garrett -9s?
The add doesnt mention -9s - that's something you've read into it. You appear to have assumed the HKS statements are in comparison to -9s, which is not correct.
do the GTSS's still carry different internal specs over the -9s?
No. They come out the same factory(s) (Garrett's factories around the world, my -9's came from their Mexico factory etc), it wouldn't make sense if Garrett built the entire complete turbo to HKS' specs (minus actuator), and then for HKS to just go and open them up and change it again.
Not doing English correctly?! At no point did I mention that they are magically bigger. I am basically only asking whether this sentence:
The clearance and shape of the compressor wheel, compressor housing and turbo housing are redesigned to optimum specs.
Yes you did, you copied the ad - which is comparing GT-SS to factory turbos. NOT to Garrett -9s
HKS and Garrett items are identical.
Cheers Lance
I didnt know garrett made the turbo to HKS SPECS, i asumed that HKS got the turbo's from garrett and from that sentence i posted earlier... I misconstrued to be HKS putting their own internals in. (Just like -5s to 2530s)
Anyone that says GT-SS & -9s are different, is full of shit.
The only difference is the actuator - HKS supply it with the kit. With Garrett you need to order.
GT-SS were under licence from Garrett for a few years, and thus -9s only came onto the market by Garrett around 3-4 years ago where previously you could ONLY by then from HKS - with the ridiculous mark up.
2530s and -5s however there IS a difference in the wheels, and this is signified by the different CHRA numbers and ID tags.
Hks Gtss CHRA = 446179-65
Garrett -9 CHRA =446179-65
Same CHRA number means same ball bearing center WITH same size/spec wheels attached, and as we already know the comp and turbine housings have the same A/R between the two.....
Sooo.....Go have a beer, and reminisce on the good ole days :yes:
Out of interest I was told by a turbo whore friend who used to have a bedroom full of car parts that the HKS turbo use a steel ball bearing cage where as the Garret are plastic. Any truth to it or maybe that was one of the things that differentiated the 2530 and -5s
Ok thank you GOJIR4, I just saw the GT2860 and thought I was in the right place.
Yes I'm aware that the turbo is not a bolt on, the reason for my queston was because the factory air intake was on when the car was bought. I guess thats why its now carcked and has a rough idle, some one has fitted a 2.5 over a 3inch (must have heated it up).
Edited by 1300
  • 2 months later...
Thread bump. Great thread guys!
Ive had -5s and GTSS, the -5s felt exhilarating whereas the GTSS IMO were boring. But like many have suggested, depends on your application.
I'm pulling off my GTRS snails at the moment...what fun that is working out of the engine bay.
Mine is far from a weekender which is sad but true.
GTSS setup made 325awkw @ 23psi
-5 setup made 340rwkw @ 19psi (I question this though as that number sounds a bit high, maybe a happy dyno?)
Throw those RS' s in the dumpster where they belong!!!!
If anything, that's a tad on the lower side. Ash made 365 ish at around 19 psi IIRC.
Reading posts like this always makes me wonder if i went the right way with my -9's Dam you!!
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
