yeah made up.. because the engine is in a american spec nissan z33 350z, i can get some big dumps made for it... and it will be pretty cheap here, about the same price as importing a set.
what you think ?
your setup sounds like fun - maybe run the oem airbox & see how the sound changes? i'd also say its the pods that are making the noise...
ive also wondered whether i should upgrade my hks split dump pipes to the bellmouth type / 3 inch dumps if im aiming for 350awkw with a 2.6ltr & -5s? any thoughts?
i am only running 16psi of boost atm... its summer here and even at 2am its 40deg c....
also i am running stock r32 gtr dump pipes because the hks dumps i had on the 2510 did not fit for some reason.
how much power would these stock r32 gtr dump pipes be robbing from my setup? i was thinking of getting some replacements or get some bad ass 3" ones made, what would be better?? or is it not needed? come winter i really do want around 340rwkw
-9 on an RB30..its very responsive like a NA.
Sounds like a pretty lethal setup. Add e85 to the mix and you should
be well above 340rwkw in the winter. Some people have hit around 370rwkw on e85
on a standard 26 with -9s. Power figure yet to be backed up with 1/4 run though.
Ditch the 32 dumps for some 34 dumps. 55mm outlet compared to a 59mm outlet
on 33 dumps but you can see the inlet of the 34 dumps promote flow that is more laminar.
That and its quite a bit bigger in the middle as well.
Keen to see how this turns out for you
we dont have e85 here, but our 98 is good, real good... 330 - 340kw on 98 will do me just fine.
i am going to get a set of r34 dumps i think.
I'm using HPI dumps with my -9s and making 350kw on 98
So when winter hits in sure you can get there aslong as the rest of the exhaust is up for it
front pipes measure 61mm & collector is 88mm - is there an advantage to running larger diameter dump pipes if my front pipes are this size?
my current hks split dump pipes are 59mm
What size are your front pipes, Marko?
thats what she said hey Paul :)
makes me wonder how much of a restriction my rb30dett was when i had it - that also ran hks split dumps with only a 3.2" inch system & slightly smaller front pipes.
what size front pipes u running big boy?
Jesus, they're tiny!!!
I'd say not, unless you're gonna change front pipes too.
far out that r they straight pipes then (no cat)?
I thought u said 3.5" was your old cat back exhaust
Two mufflers, no cats, twin tips... Almost looks standard...
May have, but I've had this system on for close to two years.
    • I vote go red. Only because I hate keeping gloss black clean. Was no worries helping out either! Glad you've survived the rain outs of QLD
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
