Where To Go To Get Oil Cleaned Off Engine?
brad20
 Share
grab some degreaser for a couple of bux, cover the spot in degreaser and watch is fall out.
may need to rub some off depending on the quality of degreaser or how bad the oil is on there but 9 times out of 10 itll just fall off.
dont get the stuff on your electrics and itll be fine
All good and well if you can easily get under your car but since my car sits 100mm off the ground it makes things a little difficult to see what the hell is going on. If I could hoist it up and get under it with some light it would be a different story. CBF and I just want to get someone to do it for me properly
Ask a mechanic?
I've asked a mechanic to clean up my engine bay - degrease, etc before - they had no problems taking care of it. (on my N14 SSS)
yeah my mechanic did mine once for me.
also to help with low cars, my old car sat lower then yours and my drift car rides chassis rails trying to get up anything and all i did was put the car on car ramps (using small planks of wood as a step up) and rolled under it and went to town on it with degreaser.
 Share
    • Have you adjusted the clutch pedal rod? You can wind it in to shorten it. Just can be a cnut to get to.
    • Yes sir, that was me. Fake ARP's are also a thing over here in Canada and we only order from reputable dealers. It's sad that even simple things like bolts and hoses are now also being copied... anything to make a dollar.  Story time. Like all cheap crap from China, it's even an issue with firearms. Roughly 15 years ago, I purchased a new cheap Norinco 12g shotgun. First time out in the bush with it, while firing, bolt assembly didn't lock and it fired out of battery. The receiver also being cheap steel, basically exploded in my face. I was lucky to be wearing eye protection. Long story short, don't buy Chinese junk. Also Norinco being state run and their only military arms producer, if ever they do try and take over a country, don't worry about it lol.
    • Installed  Nismo coppermix twin competition spec last year in my bnr32 with pull trans with Oem slave cylinder. The point at where the clutch disengages/enages is right at the top of the clutch pedal, meaning I barely have to push the pedal down for the clutch to be disengaged.  You guys that have the same combo are you experiencing this high pedal bite point??   Secondly I’d like to have the disengagement point lower meaning I have to push the pedal more(further not effort)for it to be disengaged.  I’m thinking to use a Nismo big operating cylinder(bigger bore at 13/16 vs Oem 3/4) which will require more pedal stroke to get the equivalent movement at the clutch fork. But I see Nismo web site says not to mix these 2 as the Nismo big operating cylinder doesn’t have enough stroke to disengage??? Any folks run both the coppermix twin pull with Nismo cylinder??    Thanks in advance for the replies but prefer only guys with pull clutches to respond. thanks
    • Any chance u could let us know where your based ?
