  • Replies 155
nicknick - thanks for the timeslip (what about your car?) Also was this done in the gtr you were selling for $15K on here in the last week or so? Without being too much of a synic that timeslip could have been for a rail that missed the start then got back on it 3/4 track!!
https://www.sau.com.au/forums/topic/32287-10sec-gtrs/page/2/#findComment-654242
K - i jumped the gun the car pic hadn't been posted yet. So thats your car that is in HPI GTR Special #4. That article supports your story that it still has the original box. I think you will have to admit you will need some luck keepin it together if you plan to run 10's.
https://www.sau.com.au/forums/topic/32287-10sec-gtrs/page/2/#findComment-654249
nicknick that is a sweet lookin car - However I am suprised that the box lasted longer than the twin plate HKS clutch. I'll let it go with respect to your 1/4 mile run but I will say that is the slowest time I have seen for that kph (I understand your clutch was f##ked, it just seems odd that you got drive in higher gears to obtain the terminal speed). Gettin back to your comparison of the rex boxes, aren't they the weekest part of subaru's driveline eg 2 -3 good launches and they are stuffed. Anyhow, lookin at your mods you should run low11's with ease. I wish you the best at the track in the future!
PS: What was the go with that 15K gtr you needed to sell to buy a house but now you have this beast?
https://www.sau.com.au/forums/topic/32287-10sec-gtrs/page/2/#findComment-654537
dean from upimports did the work, some of it, i dont know who BMT is,i know you think its odd that it run a poor time running 186kph, imagine my face when i saw the time sheet. i sold the stock gtr quick so i can invest in a good property oportunity, doesnt mater i can always buy another one for run around.
at to BLITZ i live in sydney i bought it from melbourne, that was a fun drive, think i clocked it 3 times on the way back, twice on the straight and once uphill, first time ever i a car. thanks benjiman74 for the support, hopefull i get my time that i want so i can finally have the paper to prove it.
https://www.sau.com.au/forums/topic/32287-10sec-gtrs/page/2/#findComment-654792
its a T78-33D the biggest of the T78's, when the box was rebuilt like i mentioned, my mate told me there is no reason the box shouldnt hold the power, its been holding it till now and it was perfect inside( he said like new) i mean that should say something about the box after 9 years of driving. and for the low 11's comment, i think it should be possible for a mid to low 11 hopefully. we wont know till we try,...
https://www.sau.com.au/forums/topic/32287-10sec-gtrs/page/2/#findComment-655361
According to the time slip, you got a 60ft of 2.393..... Either your getting heaps of wheel spin or she's bogging down....
Either way, a good launch should see you well into the elevens......
What rwkws she pumping out???
https://www.sau.com.au/forums/topic/32287-10sec-gtrs/page/2/#findComment-656936
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
