And Roy, you werent seriously paying out Doughboy were you? I thought you were having a sarcastic go at nicknick.
Depends...if he lets me overtake him at track days, just to preserve my fragile ego then all is good. :) ...or even better buddies up with me for the Dutton Rally, his combi can be the spares van :(
https://www.sau.com.au/forums/topic/32287-10sec-gtrs/page/7/#findComment-683575
  • Replies 155
Ha Ha Ha Ha Ha Ha. What a laugh. When will these dreamers learn to actually pull a decent time before blowing their bags. Thats the only problem with these forums - too many dreamers. Did this "10 sec GTR" run at WSID???? probably not.
https://www.sau.com.au/forums/topic/32287-10sec-gtrs/page/7/#findComment-687374
Yep. It is. And it has run a nine. And it will again soon. Even if it never ran again, I still pulled the time.
Fact is, this dickdick guy has insulted people I know.He should pull his head in & run a decent time before dreaming on & sticking it up other Skyline owners that are nothing but helpfull & decent people.
As for my car - it has been off the road for a while(have been playing with other cars) but will be up & running soon with a totally new setup.
What will it run? I'll wait & find out before posting on here wont I!!!
https://www.sau.com.au/forums/topic/32287-10sec-gtrs/page/7/#findComment-687441
True. On another note. Alice would be wiked. Not far from no speed limits - I wish.
Just lost my licence for the 15th time!!!!! That is not a typo!!!
Got to the point where I am learning for my pilots licence. At least up there there is no speed limit. Biggest problem is I cant work out how to fit the wings on my GTR yet.
https://www.sau.com.au/forums/topic/32287-10sec-gtrs/page/7/#findComment-687456
well, I force myself to run thru the no speed limit zone on the 50k trip to work each day....of course its not as fun as it could be with the speed limiter still in :D Also, not a corner to be found for miles out there
but, its not *really* that hard to stick to the speed limit is it? You need to get out on the circuit more.....I'd lost my license 3 times before 20 (pretty poor effort), but now I just get it out of my system on the track instead.
https://www.sau.com.au/forums/topic/32287-10sec-gtrs/page/7/#findComment-687461
Hi Munro, get that pilot's licence, fly to New Zealand and get a driver's licence there. Works for a few guys. But you are so well known, Adelaide ain't that big and your cars are easily spotted, so it probably wouldn't work for you.
On another subject, that other turbo car of yours, it has a water to air intercooler doesn't it? If it has, how do you find it works in the summer heat?
https://www.sau.com.au/forums/topic/32287-10sec-gtrs/page/7/#findComment-688134
It's legal to drive here with alot of international licenses. There was a scam a few years ago where people were getting their international license (a generic one issued from NRMA and other "motoring" groups) without having a "real" license first. I'm pretty sure you can still do that.....
https://www.sau.com.au/forums/topic/32287-10sec-gtrs/page/7/#findComment-688354
Hi Steve, at last count, about 1 million visitors to Australia each year drive legally without an Australian license. I have no idea how many do it illegally.
Hi Chris, I don't think they have international licenses anymore, you just use your own country's licence, that's what I do when I go overseas now.
If you have an NZ licence, you just have to remember the formulas....
I = U (as in fush and chups)
A = AR (as in larmb chops)
Sheep = Gurlfriend
All Blacks = Gods
Once you have that mastered, you can pass yourself off easily.
https://www.sau.com.au/forums/topic/32287-10sec-gtrs/page/7/#findComment-688420
When i went OS, i was told that an OZ licence is all thats required to hire cars from OS outlets, so was good enough for me
... that said to drive in Indonesia you have to be OVER .05 otherwise its just not fun, and its far too easy for the locals to psyche you out with their driving, a bit of dutch courage and you can mix it with the best drivers that Indonesia has to offer. :P
I sure as hell hope that NSW RTA doesnt recognise an Indo licence as an quivelant, or French for that matter, they are nutz behind the wheel as well :flamed:
https://www.sau.com.au/forums/topic/32287-10sec-gtrs/page/7/#findComment-688524
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
