soooo....
where can i grab brakepads round melb @ a good price asap? have deca on the weekend and i dont think i can do another day on the current ones
looking at pads for track and street duties....
Hamish.
Call GSL rally sport and you'll have them on wednesday from qld.
Get HP-X or the A1RM's for a higher temp pad. I'm using A1RMs and they're good for track work too.
http://www.skylinesaustralia.com/forums/Qf...ak-t301207.html
http://gslrallysport.com/shop/index.php?ma...p;products_id=5
For $79 you can't go wrong.
https://www.sau.com.au/forums/topic/322893-brake-pads/#findComment-5264455
try Race Brakes Melbourne in Yarraville place.
They can help you out they got plenty race experience in their background.
There are different brand in stock, you can go pick a brand and the quality to choose race, track, street etc.
Give a call for more info.
Address:
2 Minnie Street
Yarraville Vic 3013
03 9687-7222
Cheers Peter [/size]
Edited by Peter - La La Land
https://www.sau.com.au/forums/topic/322893-brake-pads/#findComment-5265206
A1RM's are track pads and chew through rotors really badly in cold mornings. I used them on my daily and needed new rotors after 30,000km. After speaking to QFM, they are track oriented pad and will chew through rotors quickly when they are not up to temperature (ie daily driving)
I have QFM HPX pads now which are great for street. Cheaper and better than Bendix Ultimates but I have been told they will not hold after a couple of runs on a track.
For motorkhana/daily driving the HPX will be your best option.
https://www.sau.com.au/forums/topic/322893-brake-pads/#findComment-5265283
thanx for the replies guys...
I ended up having a look and my current ones should survive deca...
i bought some nismo type R pads that go on in a week or so :happy:
If you get run out on saturday I will have some spare pads. Just come and see me.
https://www.sau.com.au/forums/topic/322893-brake-pads/#findComment-5265287
Brakes plus in Highpoint. EBC Reds for teh brembos cost me $600 or so. not too bad and a great pad for street and track, also no icky black dust on your wheels, teh powder stuff that does come from them wipes off with wet sponge due to no metal compounds!
https://www.sau.com.au/forums/topic/322893-brake-pads/#findComment-5266956
    • 2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan  Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor.   Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s     I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
    • Realised I never posted this , also I never got a price
    • I'm glad to hear you've joined the SKI club. Spend the Kids Inheritance.
    • I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
