Hi guys, in regards to my old thread;
http://www.skylinesaustralia.com/forums/Rb...25-t321488.html
The pistons/crank/rods were dummied up today and have found that the RB26 pistons (using standard ones as dummies), the dome part is hitting the head.
i am using a RB25 NEO head which i believe has a smaller CC compared to R33 RB25 head.
Is it possible to either:
a ) machine a RB26 piston dome flat (will be using ACL pistons, pending budget so will either be forged or cast items)
b ) custom make a piston with either a dished or flat top to suit with RB26DETT/RB25DET compression ratio - 8.5:1 to 9:1 range? (If so, who makes custom pistons and approximately what cost would i be looking at for a set in either 1) forged 2) cast)
c ) custom thick headgasket to help make it clear with RB26DETT off the shelf pistons?
Here what happens when the off the shelf RB26 items are used, you can see where the valves hit.
http://forums.nicoclub.com/rb26-crank-rods...io-t475298.html
Ideally i would like to keep this head and not change to a R33 head which will require rewiring, different injectors,cams etc.
Any help much appreciated.
https://www.sau.com.au/forums/topic/322949-piston-clearance-issue/
You can get CP pistons made which take 4-6 weeks. I'm trying to find out if anyone else will aswell.
Speaking to a few machinists/engine builders; getting the combustion cambers machnied and running a thick head gasket (2mm) they were still getting big compression.
The only way to do it properly is to get pistons made.
Edited by aleks
Almost any piston company will make custom pistons. Not cheap though and from what ive read you're trying to do all this on a budget.
For a start, there's Mahle, JE, Wiseco, Arias, CP, Cosworth, ACL etc
Id start at ACL then try CP, or if the budget allows about $1700 call Specialized Piston Service in melbourne
I've checked with ACL, they dont make it anymore.
I will be ringing & emailing a few companies tomorrow and hopefully get something sorted soon so my car and be completed. waiting 4-6 weeks for them to could is very time consuming :happy:
If custom pistons is the way to go then thats what ill be doing.
so i assume machining the dome is a no go?
  Adriano said:
Is the dome hitting hte head or the valves, you can easily get the pistons flycut to clear the valves
The dome is hitting the head. Will "flycutting" affect the pistons strength/integrity at all? Who can do this sort of service, the bloke machining my block?
  Simon-R32 said:
is this a neo only problem? any reason you cant use Rb25 psitons to suit a neo or is there nothing available?
interested as im looking at doing a build down the track.
I am using RB26 crank/rod & pistons in a RB25 Neo block.
You can get it to work straight up with a R33 RB25 head as it has a bigger combustion chamber - 63cc compared to 50-51cc.
do any companies make dished pistons for RB26?
hopefully swiper the fox see's this and put some input into this :happy:
I will be ringing & emailing a few companies tomorrow and hopefully get something sorted soon so my car and be completed. waiting 4-6 weeks for them to could is very time consuming :)
Give quantum racing industries a call up on the south side of Brisbane. They are the main importers and distributors for the CP Piston range.
07 3290 5911
Wait, I want to know how that happened.
How long did the motor run for before you found it like that? that looks more like detonation damage than it does valve damage.
Here's what happened last time I saw a piston touch a valve:
And I imagine if the piston was touching the head with the dome that the dome would have damage on it... but from the pic it doesnt seem to have much of a mark on it..
Also, if that was touching, it would have nuked itself within a few seconds of running.. more so that eating abit out of the piston crown.
Would really like to hear more about how that happened.
Titan - why not? i guess this forum is no good for info and input from other members to help others out then.
GtScott - that is not my piston. just some other bloke i found who did the same thing in the us. if you look closely at the picture towards left side of the piston, you can see circle marks from where the valves hit.
200 - i'll be contacting them today. thanks for the details :)
So from the top of your heads, are there any off the shelf items for rb26 that are dished and not dome?
Forget about rb26 pistons. HIGH COMPRESSION
Lewis engines have Arias pistons for RB25/30 neo heads and engine listed on their site for $1375
Just spoke to quantum racing and they want ~$1520 to get CPs made 4-5 weeks they said.
About to call lewis engines see if they have anything in stock....
Edited by aleks
im not a fan of the arias gear, i would spend the dough on CP's or JE for sure.
I emailed rocket industries for Aria items. hoping they may be able to supply a 26 piston with dished head if not then a price on custom units. i'll contact lewis as well unless you beat me to it.
alek- are you doing 26 internals as well or just 25 neo?
would be to use a 25 piston with the 26 rod since the rods are the same?
hopefully swiper the fox see's this and put some input into this ;)
Doubt it, Admins banned him..
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
