Ha ha, nope mirror was facing a funny angle!!
Had a look in the daylight today and the only things that copped mirror glass was, driver window, b pillar, and rear spoiler blade.
Have to wash the car to see if any paint was damaged.
Also went back to the spot where it happened and picked up the plastic bits of the side mirror off the road.
  • 1 month later...
Fitted the pump, injectors and airflow meters. Then played with injector and airflow meter %'s to get it to run! Wide band 02 up the tail and made it run well enough to drive to the tuners. New set of spark plugs, 18PSI ran up 285AWKW.
The boost controller wouldn't hold boost properly above 18 PSI, and it was suggested that I get something better (EVC 6), as well as some newer cam gears as the old one's don't have timing marks. It now drives a lot better with the car pulling cleanly past 8000RPM where before you could feel it drop off after 6500-7000RPM. Makes me like the -9's even more! 22PSI is the next aim once boost controlling is sorted!
post-12712-0-24970800-1314364016_thumb.jpgpost-12712-0-37827400-1314364027_thumb.jpgpost-12712-0-94315900-1314364031_thumb.jpg
Just to get to the fuel pump, rear stiffener and brace need to be removed, also: rear seats, blanking plate, computer racks, plugs and connectors etc.
Injectors and AFM's are the easy part as usual!
I removed some dead weight, it added up to 9KG, but left the rear strut brace in of course.
post-12712-0-02509400-1314364041_thumb.jpgpost-12712-0-23562400-1314364044_thumb.jpgpost-12712-0-12394600-1314364049_thumb.jpg
I removed the carbon insert in the front bar to fit some mesh and refitted.
I suggest you run hks actuators if you want to run 20-22 pounds without the boost curve falling over.
My turbos spike to 1.5bar then drop down to 1.3bar by redline, i havent been able to get rid of that spike :(
Thanks Nick, I'm looking forward to more, but it's so good right now!
I'm already running the HKS adjustable actuators, as per previous posts.
Cheers Chris, They are the same size physically, but the nismo offers more flow. I just wanted a fresh bolt in solution. The 044 will outdo it at higher boost, but not for my aims.
Ha ha it's staying on the car Luke!
hey mate cars coming along beautifuly !
what boost control problems did you have Sean? those wastegate actuators should be holding boost much more steady as the boost controller isnt working as hard. did it spike to 20 or so psi then drop to 18psi by redline?
thanks
I'm thinking it is more the wastegate actuators fault, they are holding 11.5psi with controller off, so I will need to put in more preload on the actuators.
Controller is struggling to hold higher boost, 18psi+ for example. Graphs I got today tell the story.
AWKW
Once I sort out actuators, it'll will be ready for 22psi :D
Wow that boost curve looks EXACTLY like mine.. good thing im getting rid of my twins next week! :action-smiley-069:
Great power considering max power is being made at only 1.2bar :laugh: almost exactly what i made with -7s.
Edit: does anyone think its a possibility that the stock bovs are opening slightly when on full boost hence the boost falling over? I wonder if stronger BOVS will make any difference.
Edited by snozzle
  • 1 month later...
Got some new bits to fit, nismo stuff!!!
So I fitted the Nismo MFD upgrade boards and new map sensor. Did the calibration and it all works.
G sensor, lap timer, oil pressure, 2 bar boost gauge and more scale on the other readings.
Also got the oil air seperator tank kit, and I'll probably fit that soon.
You know it Bob :thumbsup: thanks again.
Thanks RBish, the nismo mafs I chose because, I have played with map sensor based stuff on the 32 I used to have. Takes longer to get right and altitude stuff it around too.
I got them for $700 or so new but they usually go for around $900. Good to have fresh bolt in stuff.
really looking forward to this :D
when's it going in next?? and who's doing the tune??
i probably should get heavy duty actuators before getting mined sorted too
Patience grasshopper!
Here's some pics of the oil/air separator tank fitted. It took 2 hours to fit, top hoses were easy, then jack the front up to get to the rear turbo oil drain fitting and replace it with the new 3 way fitting. Only had to remove the bottom chassis brace to get in there, and use some uni drives to get to the bolts etc.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
