Yep, and a nice big power steering fluid stain on the ground from his ute lol.
Well this arvo, temp fitted the turbos to line up piping, then bolted them up.
Points to note;
These GTX turbo's are not a bolt on turbo for RB26's.
You need to buy the rear housings seperate.
I chopped the intake snout and outlet to weld on stock piping, and got the flanges welded on the outlet pipes to bolt up to the twin turbo pipes..
Also port matched inlets to compressor housings, as they are 3inch inlets, and inlets are 2 inch on the stock pipes.
Wastegate actuator mounting bracket holes need to spaced out more to bolt up to compressor housings.
Oil and water lines on the CHRA don't have anywhere to bolt to the compressor housings (seemed fine without them).
Oil drain pipes also needed the holes diegrinded.
Thanks guys!!
As you can see Piggaz special part is on, the backing plate :D
post-12712-0-29282300-1352109247_thumb.jpgpost-12712-0-24667700-1352109238_thumb.jpgpost-12712-0-34345700-1352109230_thumb.jpg
And Eric's flywheel locking tool, awsome bit of engineering!!!
post-12712-0-78540200-1352109226_thumb.jpgpost-12712-0-25600600-1352109222_thumb.jpgpost-12712-0-16624300-1352109218_thumb.jpgpost-12712-0-19916500-1352109208_thumb.jpg
Gearbox is on too. Just a few little things to go.
Tuesday was spent finishing off engine accesories and piping, as well as exhaust, oils, belts etc.
Cranked engine over with no plugs to get oil through the oil cooler and engine. 20 seconds later, oil pressure :D
Filled radiator up with water only to settle head gasket sealing material, and once I dump the run in oil, I'll put in coolant.
Once it was ready to go, it fired up straight away, smooth and quiet. Like it never got pulled apart!!
So bedded in the rings going up the blue mountains and I've put 270kms on it so far. Next is another oil and filter change then tune!!
Pic of my 'standard' setup.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
