My Non V-spec R34 has the nismo version 2 MDF and i can see the intake and exhaust temp.. Not too sure wheree the sensor is located tho...
Cheers.
Matt
There are temp sensors located in the drivers side of the intercooler core, and the dump pipe just before the front pipe flange. They only provide signals for the MFD and dont link into the ecu.
The nismo upgrade kits do come with extra sensors, too depending on what type/version. Like 2 bar reading map sensor, instead of 1.2bar.
Also, I'm going to add upgraded swaybars to my list :P.
Thanks! Got an e boost street, black box. Nice and compact.
Damn you Steve-o!! My R32 would of been mad fun on texi!
A couple of pics when I was parked at texi. Surprise upgrade visually is the nismo sideskirt extensions that help fatten car lol.
Mate of mine painted em for me after I fixed em up and got 2 pac dg white colour matched.
  • 1 month later...
Got the wastegate actuators and fitted em up. Was a real pain to do as there is no room, but all good now.
Also got a hold of a nismo cat converter to help free up the exhaust a bit more. I'll fit it up when I can be bothered crawling under the car again.
Sway bars have been ordered in too. :P
why not just get a standard high flow cat from ebay etc? like a 120CPI?
There is a place for EBay parts.... and they call them GTST's.
Nobody in their right mind puts ebay parts on their GTR(unless its wearing a genuine Nismo, or equalivent brand name).
Can i ask, is it still wearing TE-37 look a like ROTA's, how are those.... lot of people say "mean" things about ROTA wheels... :thumbsup:
Will be interested !!!!
but dam they look the bizzz
I don't usually get ebay gear, just my choice.
I've had a metal cat (barrel type) fall to bits on my last car, and it was a well known one too. Don't think an ebay one would handle it!
Yep HKS actuators. Came with crush washers, zip ties, hose, t piece, instructions and yellow jap stickers lol.
I'm very happy with the Rota's, considering they only cost me $1300, not including tyres. Would of liked more dish, and they would look better if I lowered the car :P
I'd love some advans or similar, but don't have $3800+ handy :laugh:
The only thing I had to get was hub rings to center the wheels on the hub. If the stock wheels had an offset of +12 I wouldn't need the rota's!
Fitted the sway bars this weekend, less roll now, and one of the guys thought I had aftermarket coilovers lol.
Nismo cat is in. You don't notice how bad the compliance/high flows are until you get a better cat!
Got a brand new HKS High power silent stainless steel exhaust and fitted that too, so shiny! Now there is no more kinked bend piping, crappy resonators and horrible drone.
It is nice and quiet when you want it to be and has a great note when the go pedal is pushed.
It all bolted up sweet and everything clears, no more exhaust hitting the rear diffuser either.
Now the engine is willing to rev out a lot more. Me thinks it needs a dyno tune to 'optimise' the setup! Will soon be reaching the limits of stock fuel injectors and AFM's.
Also got a brake master cylinder stopper to fit at some point.
Next on the list once my wallet recovers is probably rego.
Still have to get:
Nismo MFD upgrade
New front rotors
fire extinguisher
post-12712-1288524644_thumb.jpgRear swaybar, I may fit better swaybar links.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
